Author Topic: Carburrettor cleaner VE injector pump  (Read 5096 times)
May 02, 2008, 02:59:07 pm
smutts
  • 720
    ClackClackClackClackClack
« on: May 02, 2008, 02:59:07 pm »
Carb cleaner is wonderful stuff for giving you cancer, dissolving assorted congealed crap, gummed oils, varnish, plastics, etc.
Has anyone had any joy with unsticking the vane pump blades in the Bosch VE diesel pump with this witches brew? Or are the assorted seals in the pump destroyed by this stuff? :?
No. I don't inhale! :twisted:
Reply #1May 02, 2008, 04:31:42 pm
« Reply #1 on: May 02, 2008, 04:31:42 pm »
Diesel purge would probably be a safer option
Reply #2May 03, 2008, 04:56:48 am
« Reply #2 on: May 03, 2008, 04:56:48 am »
Quote from: "burn_your_money"
1x and even Giles has said that the diesel purge is a little dry, so add some kind of lube.  veggie oil or bio?  :lol:
Reply #3May 06, 2008, 03:11:11 pm
smutts
  • 720
« Reply #3 on: May 06, 2008, 03:11:11 pm »
Cheers! :)
Reply #4May 10, 2008, 06:49:44 am
riddleyo
  • 130
« Reply #4 on: May 10, 2008, 06:49:44 am »
carb cleaner would cause havoc on all the rubber seals!
1985 VW Golf Diesel 1.6L N/A
My Build Thread: http://www.vwdiesel.net/forum/index.php?topic=14607.0
Reply #5May 17, 2008, 06:56:24 am
« Reply #5 on: May 17, 2008, 06:56:24 am »
The blades get stuck from sitting with old fuel in them or running poor quality fuels, veggie oil etc.
You can sometimes get them unstuck by filling the pump manually with a good lubricant and spinning it over without the engine firing.
You'll know the blades are stuck if the pump will not pull fuel into itself or if it's having hard times starting and low power. I think it's possible for only a few of the blades to stick, but I'm not sure.
