Author Topic: Whats wrong with these pictures?  (Read 5177 times)
May 02, 2008, 01:29:03 pm
Baxter
« on: May 02, 2008, 01:29:03 pm »
Clue, It's going in a T3 (Vanagon)
Reply #1May 02, 2008, 01:35:30 pm
carrizog60
  • 978
« Reply #1 on: May 02, 2008, 01:35:30 pm »
isnt a AAZ?
well,what could be wrong is that the engine is new or look alike and the vanagon may not be :lol:
Portugal
Reply #2May 02, 2008, 01:41:20 pm
Baxter
« Reply #2 on: May 02, 2008, 01:41:20 pm »
It is AAZ.
It is new (more or less)
It's going into a Westy Atlantic, so it's worthwhile spending the money..
Reply #3May 02, 2008, 01:41:32 pm
« Reply #3 on: May 02, 2008, 01:41:32 pm »
only thing i notice is that it doesn't have the sump vent to crankcase vent.
Reply #4May 02, 2008, 01:42:05 pm
Baxter
« Reply #4 on: May 02, 2008, 01:42:05 pm »
Warmer...
Reply #5May 02, 2008, 02:13:32 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #5 on: May 02, 2008, 02:13:32 pm »
I'm scoobied. :?
Reply #6May 02, 2008, 02:43:47 pm
« Reply #6 on: May 02, 2008, 02:43:47 pm »
The problem is it's not in my garage.
Other than that I see no problem at all.
Pretty..
Reply #7May 02, 2008, 02:57:40 pm
Luckypabst
  • 502
« Reply #7 on: May 02, 2008, 02:57:40 pm »
Quote from: "libbybapa"
When it's tipped to the 50° install angle, the oil separator will not function very well.
Andrew
Could you elaborate a bit more, Andrew? Mine looks the same and it was "plugged up" and took a good reverse huff to clear out (synthetic oil sticks to lips real nice). Maybe mine needs straightening out...
Chris
'82 TD Westy
'81 NA Caddy
Reply #8May 02, 2008, 03:26:23 pm
Tintin
  • 1279
« Reply #8 on: May 02, 2008, 03:26:23 pm »
I dont have an AAZ in my face, but the valve cover part under the oil separator seems to be higher than Golf/jetta AAZ, I only see a valve cover like this on a 1.6L diesel vanagon, but dont fit on AAZ.
Reply #9May 02, 2008, 03:36:35 pm
Tintin
  • 1279
« Reply #9 on: May 02, 2008, 03:36:35 pm »
Maybee an original 1.9TD ABL from T3.
Reply #10May 02, 2008, 04:18:25 pm
Baxter
« Reply #10 on: May 02, 2008, 04:18:25 pm »
The rocker box is an experiment.
I have cut out the breather gauze section out of a 1.6TD cover and welded it into a AAZ cover to try to cut down, or cut out the "50 degree instal AAZ running on it's own oil problem!"
It took hours!
I'm never doing another!
I was trying to achieve what VW did for the 1.6TD install from the factory, but to a AAZ rocker box.
I have a fresh engine, didn't want to kill it!
Only time will tell, can't see why it won't work though.
Also spoke with the turbo company I use locally, they are going to build a hybrid for it, from new parts, he said he would look into it further but he mentioned using a K16 compressor, reckoned on that a K24 in a van with a AAZ would be far too laggy and for not much money they could build a decent, reliable turbo thats affordable, so again, only time will tell.
 8)
Reply #11May 02, 2008, 06:12:55 pm
« Reply #11 on: May 02, 2008, 06:12:55 pm »
haha i was gonna say that but i figured i was wrong haha i should have gone and looked at one of my aaz covers
