Author Topic: 1.6TD jetta. tach question  (Read 5273 times)
Reply #15April 29, 2008, 07:04:49 pm
  • 5104
« Reply #15 on: April 29, 2008, 07:04:49 pm »
i did this on my jetta i used the cluster out of a cabriolet, works beautifully.  follow the conversion in the faq.  if you can solder this job can easily be done by you
Reply #16April 29, 2008, 10:08:49 pm
TedV
  • 182
« Reply #16 on: April 29, 2008, 10:08:49 pm »
The opto sensor circuit I made from the 4crawler schematics worked fine plugged into a test tach.  Looks like the tach in my Scirocco that worked fine 2 years ago is the problem.  I love VW wiring and electronics.
