Author Topic: 1.9 td crank pulley issues  (Read 5775 times)
April 25, 2008, 05:41:41 pm
lews9146
  • 39
« on: April 25, 2008, 05:41:41 pm »
hello. first time poster but many questions to follow. I have purchased a 1.9 td AAZ motor to swap into a Mazda RX7(that story later):) Since buying the motor I have learned that the AAZ motors had problems with the crank pulley. My questions are, what exactly happens to the pulley and how would you tell if it's been updated or replaced? I was told it had been replaced but since I'm new to VW's I have no way of telling.
While I'm on the subject a related questions.
In doing the swap I see that the p/s pump is hittting the steering rack in the donor car. if I can remove the p/s pump(and locate it elsewhere) It will fit with no further mods to the subframe. Were there any 1.9's that didnt have p/s steering and if so how do you apply tension to the water pump pulley/belt?
thanks in advance
lewis
Reply #1April 26, 2008, 10:01:30 am
« Reply #1 on: April 26, 2008, 10:01:30 am »
seems like a big dilemma with that damn power steering pump.  i myself am going to electric-hydraulic power steering.  the motor i bought from Europe (PD130  :twisted:) didn't come with a pump, which i am not objecting since they can rob upwards of 5-10 hp in the upper rpm range.
Reply #2April 28, 2008, 01:04:50 pm
Kneale Brownson
  • 120
« Reply #2 on: April 28, 2008, 01:04:50 pm »
Crank pulley can develop a wobble from either the keyway on the end of the crank or the machined key in the pulley becoming distorted or the vibration damper failing.  The latter is just a matter of replacing the damper, which was my circumstances luckily when I reported about my wobble here a year or so ago.
Here's a good crank end keyway:
And here's a good pulley inside:
I had to replace the vibration damper to get rid of a significant wobble there.
My understanding of the crank end damage is that it occurs because the bolt used originally to fasten the pulley to the crank would loosen or stretch while in use, allowing for pulley movement.  The old bolts, reportedly, no longer are available and VW now supplies ones developed for the TDI engines.  The newer bolts have a button on the end, visible through the crank holder tool I made for loosening the crank bolt:
Somewhere on this site is a write-up about repairing a bad crank end that had really scary photographs of a damaged crank end.  However, the write-up lost its images because the place on the web where the author had the pictures posted shut down.  So you no longer can see the scary pictures.
