Author Topic: N/A to turbo questions  (Read 7078 times)
Reply #15April 26, 2008, 10:35:35 am
vdubin_g60
  • 73
« Reply #15 on: April 26, 2008, 10:35:35 am »
i did the porting there was a lot of black soot in it.
Reply #16April 26, 2008, 07:16:41 pm
vdubin_g60
  • 73
« Reply #16 on: April 26, 2008, 07:16:41 pm »
some questions i still have
How much fuel do you need for a k24/t3. Ive been turning the fuel up but would i have to go into the pump timing? na pump
also what can a guy use for the oil lines? tap on top of the oil filter and on the oil pan-anywhere?
so all i need is a oil filter housing tapped, tap the oil pan. find a turbo
piping for an intercooler and an intercooler. oil lines. egt probe and gauge boost gauge anything im forgeting?
would i need a intercooler right away if i run low boost?
where can i find a new or rebuild t3 for a good price  and what size is best
what is a good/cheap egt probe and gauge to use that others are happy with?
Reply #17April 26, 2008, 08:00:15 pm
vdubin_g60
  • 73
« Reply #17 on: April 26, 2008, 08:00:15 pm »
ya the bracket bolts to the downpipe holes
Reply #18April 26, 2008, 08:00:57 pm
vdubin_g60
  • 73
« Reply #18 on: April 26, 2008, 08:00:57 pm »
does anyone know what thread size fits in the holes?
Reply #19April 27, 2008, 07:31:30 am
boxer246
  • 109
1.9 manifold
« Reply #19 on: April 27, 2008, 07:31:30 am »
Everyone's saying the 1.9 intake with the "D" ports will fit a 1.6 head.......yes, it will physically bolt up, but the 1.6 head has oval intake ports.....you will need to enlarge your 1.6 ports to match.  I have no idea if there's enough meat there to do that.  Seems to me there is, I think I remember a few guys on this forum doing just that.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #20April 27, 2008, 03:23:38 pm
dillenger1
  • 777
Re: 1.9 manifold
« Reply #20 on: April 27, 2008, 03:23:38 pm »
Quote from: "boxer246"
well, it will work!If your not concerned with turbulence at the intake port,then theres no problem.The charge is pressurized anyway,so i wouldnt think that a free flowing transition is as important.Maybe if it were an NA,but the turbulence is slowed down when more air tries to take up the space in the turbulence with the pressure.On a NA gasser i would think it would be most important, as the velocity is more intense(needs smoother tract).This is not tested theory,just a theory. :DIm using a chopped alh manifold on my 1.6.One bonus is you dont have to worry about the bov :)
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #21April 27, 2008, 03:39:46 pm
vdubin_g60
  • 73
« Reply #21 on: April 27, 2008, 03:39:46 pm »
I already had my head machined so i dont think i will have them port matched.  i think it would be fine just not the best.
Reply #22April 28, 2008, 02:20:52 pm
bevboyy
  • 200
« Reply #22 on: April 28, 2008, 02:20:52 pm »
You can advance your pump to 1.00mm. Then turn up fuel. I would NOT do this unless you have you EGT gauge installed.
What is best is to take the oil lines and oil filter mount from a TD. Otherwise you can bend your own lines out of mild steel tubing.
Nope - sounds like a plan.
Yes, it's highly advisable - do it right, do it once..
I would suggest a T2 to K14 instead.
Search Ebay
[/quote]
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #23April 28, 2008, 02:32:55 pm
vdubin_g60
  • 73
« Reply #23 on: April 28, 2008, 02:32:55 pm »
why do you say that. t3 too much lag or  ??????
i have a t3 that needs to be rebuilt or should i get this?
http://cgi.ebay.com/ebaymotors/K14-TURBOCHARGER-S_W0QQitemZ120253918644QQcmdZViewItem
thanks for the help
Reply #24April 29, 2008, 02:38:54 pm
bevboyy
  • 200
« Reply #24 on: April 29, 2008, 02:38:54 pm »
The T2 or K14 are smaller, and make their boost quicker. Since you'll be running less than 9psi, these turbo's will flow quite nicely.
T3's and K24's make their boost around 3000 rpm.
It all depends on how you drive.
In regards to that Ebay link, I suggest looking for a good used one off an ecodiesel instead and save that money for your intercooler and piping.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #25April 29, 2008, 06:07:05 pm
vdubin_g60
  • 73
« Reply #25 on: April 29, 2008, 06:07:05 pm »
A smaller turbo would make more sense but i already have a t3 if i rebuild it. i think if i had boost sooner i would use it too much and want more and break something.
but if i find a turbo cheap i would get a small one. otherwise i will get the t3 rebuilt.
Reply #26April 30, 2008, 06:12:26 pm
vdubin_g60
  • 73
« Reply #26 on: April 30, 2008, 06:12:26 pm »
having a hard time finding a turbo that will fit the exhaust mani i have and stock downpipe.  A k14 should fit the manifold and stock downpipe?
Reply #27May 05, 2008, 03:24:44 pm
vdubin_g60
  • 73
« Reply #27 on: May 05, 2008, 03:24:44 pm »
I can;t find a turbo that fits the downpipe bolts and fits the manifold seems like some t3 turbos have the right manifold shape but have weird 5-6 holes to bolt to. seems the same with k14s
