Author Topic: just want to check  (Read 5471 times)
Reply #15April 24, 2008, 03:37:10 pm
mufflerbearing
  • 61
just want to check
« Reply #15 on: April 24, 2008, 03:37:10 pm »
yep, all pieces were gathered from 2 na engines. the injection is all from my old motor that was running great and its all on this "known good" "80k mile" longblock...
-j
Reply #16April 24, 2008, 07:30:47 pm
Quantum TD
  • 1195
just want to check
« Reply #16 on: April 24, 2008, 07:30:47 pm »
Compression test time.
Reply #17April 25, 2008, 02:59:13 pm
mufflerbearing
  • 61
just want to check
« Reply #17 on: April 25, 2008, 02:59:13 pm »
clearance on 2 of the intake valves is a little big... just out of spec, but that wont effect compression. ill change them, but not yet.
i got # 3 and 4 done but couldnt fit the adapter between the pump and #1 and 2 so ill have to figure something else out. looks like i might have an adapter for the injector that im gonna have to try out and see if it works.
so far i have about 540psi at 3 and just a hair under that in 4.
so, half of the motor is good, anyway...
-j
Reply #18April 28, 2008, 12:36:06 pm
mufflerbearing
  • 61
just want to check
« Reply #18 on: April 28, 2008, 12:36:06 pm »
had a spare moment today so i checked the compression
im getting ~500psi across all 4 cylinders.
when i pulled the 2nd injector, its tip was covered in oil...
any ideas? valve stem seal?
-j
Reply #19April 28, 2008, 06:27:05 pm
just want to check
« Reply #19 on: April 28, 2008, 06:27:05 pm »
try bumping the timing down to 0.90
Did you replace the heatsheilds after the compression tests?
Reply #20April 28, 2008, 08:32:42 pm
mufflerbearing
  • 61
just want to check
« Reply #20 on: April 28, 2008, 08:32:42 pm »
ill try bumping the timing down a bit.
i have not been able to find my extra heat shields... know of a place online i can order a set or 2?
-j
Reply #21April 29, 2008, 04:19:45 am
just want to check
« Reply #21 on: April 29, 2008, 04:19:45 am »
here one place I know of they are pretty cheap too
http://www.autohausaz.com/index.html
Reply #22April 29, 2008, 09:36:50 am
mufflerbearing
  • 61
just want to check
« Reply #22 on: April 29, 2008, 09:36:50 am »
ordered a set.
also have valve stem seals on the way and the special tool to press them in without removing the valve/head.
we'll see how it all goes next chance i get to work on it :)
-j
