Author Topic: 1.5 N/A exhaust size?  (Read 6318 times)
April 27, 2005, 09:18:18 pm
watsongs
  • 135
« on: April 27, 2005, 09:18:18 pm »
My cat converter has a large hole in the bottom, probably from sitting in tall wet grass for 3 years.  I'd like to replace it with a straight piece of pipe - does anyone know the pipe diameter?  Looks to be about 2", but I'm not sure, and I don't have the best way to jack up the car yet, so I only want to go under 1 time.
By the way, cherry bomb mufflers are kind of cheap; anyone ever put one in?
Thanks for the help
Greg
Greg Watson
'79 Rabbit, 1.5 liters of fun...
If they can get you to ask the wrong questions, they don't have to worry about the answers...
Reply #1April 28, 2005, 09:56:18 am
watsongs
  • 135
« Reply #1 on: April 28, 2005, 09:56:18 am »
How about the size?
Greg Watson
Reply #2April 28, 2005, 12:20:30 pm
janb
  • 167
« Reply #2 on: April 28, 2005, 12:20:30 pm »
Quote from: "watsongs"
How about the size?
for diesels... the bigger the better, tho I doubt if a 1.5l needs 4", 2-2.5 is likely optimum, since they do rev higher than the 1.6/1.9's
The Stealth Rabbit
VW-d's are forever
Reply #3April 28, 2005, 02:14:45 pm
vwmike
  • 1158
« Reply #3 on: April 28, 2005, 02:14:45 pm »
Quote from: "janb"
How about the size?
The bigger the better on turbo diesels. I don't think you're going to see much gain, possibly only torque loss on an NA diesel if you go much larger. 2" would probably be very generous.
Reply #4April 29, 2005, 05:55:26 am
racer_x
  • 123
« Reply #4 on: April 29, 2005, 05:55:26 am »
The 1.5L diesels had either 1 1/2" or 1 5/8" exhaust. If you're replacing the whole system, go with 1 3/4" or maybe 1 7/8" on that engine. Anything bigger won't help power much, might hurt midrage torque and will just weigh more.
Reply #5April 29, 2005, 06:17:34 am
VWRacer
  • 649
« Reply #5 on: April 29, 2005, 06:17:34 am »
No overlap on the cam means no scavenging effect from 'tuning' the exhaust. Therefore, no real downside to a bigger pipe. Two inch pipe is real cheap, but unless you plan to turbocharge the engine, going bigger than that won't help with only 50-60 hp on tap. If you do plan to boost it, then 2.5" would work great - and it's still cheap.
Stan
C-Sports Racer
Reply #6April 29, 2005, 08:06:23 am
watsongs
  • 135
« Reply #6 on: April 29, 2005, 08:06:23 am »
I'm just tring to replace the resonator for now -
Greg Watson
Reply #7May 18, 2005, 12:23:41 pm
greggearhead
  • 153
« Reply #7 on: May 18, 2005, 12:23:41 pm »
Quote from: "VWRacer"
Exhaust tuning doesn't come from overlap scavenging, it comes from the pulses that happen when the exhaust valve opens and shuts, so a diesel can benefit from that just like a gas engine.  This is really only to do with the header or manifold and downpipe design, though.
The exhaust tubing diameter (after the header/downpipe) aren't dictated by scavenging, more from displacement and hp production potential.  Oh, I have never seen/felt a loss in midrange or low-end response on a diesel from using a 2" exhaust.  Fabricating a smaller mandrel bent one wouldn't be worth the cost over simply buying a Techtonics 2" setup off the shelf.
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
