General Information
Upgrades (non engine related )
jumping out of gear
Topic: jumping out of gear (Read 5240 times)
April 21, 2008, 08:28:36 am
TOW'D
jumping out of gear
April 21, 2008, 08:28:36 am »
Hi Gang,
Our '85 golf jumps out of 3rd and 5th sometimes.
I replace all the bushings and shift rods and gave everything a good lube.
Could the motor/transaxle mounts be one of the problems making it pop out of gear?
thanks
hank
way too many projects not much time
April 21, 2008, 11:30:33 am
Possum79
jumping out of gear
April 21, 2008, 11:30:33 am »
Check your fluid. From what I have read if you run out of trans fluid you burn up 5th first. Signs are popping out of gear.
Your tranny may be toast.
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
April 22, 2008, 04:25:35 am
jumping out of gear
April 22, 2008, 04:25:35 am »
Exactly what Possum79 said.
April 22, 2008, 05:36:15 am
BlackTieTD
jumping out of gear
April 22, 2008, 05:36:15 am »
redline mtl or mt-90 are nice. worth the slightly higher cost than the standard trans fluid and it might bandaid a rough transmission for a while so you can keep driving.
April 22, 2008, 06:21:16 am
subsonic
jumping out of gear
April 22, 2008, 06:21:16 am »
If it is low, find the leak. output shaft seals?
April 26, 2008, 09:50:18 pm
commuter boy
jumping out of gear
April 26, 2008, 09:50:18 pm »
The trannies came with a "fill and forget" service requirement. Over the years through evaporation the oil level can drop enough even without a visible leak to prevent 5th gear from getting the lubrication it needs.
SOP on acquiring any VW manual transmission car is to drain, flush, and re-fill the tranny with fresh fluid to the right level.
April 27, 2008, 10:06:18 am
TOW'D
jumping out of gear
April 27, 2008, 10:06:18 am »
I drained and refilled the transaxle and let it it for a hour while I replaced the radio.
When I backed out of the garage I saw a big oil spot on the floor.
Thinking that I must have spilled some oil while putting it in the speedo hole.
I looked under again and the passenger output shaft seal was leaking in a steady drip.
I ordered up 2 new VW output seal kit and will hope that fix if the problem.
I took a look at BrokeVW for spiritual guidance-
Thanks for taking the time to do that step by step,Broke
first class
cheers
hank
April 29, 2008, 05:10:35 pm
Possum79
jumping out of gear
April 29, 2008, 05:10:35 pm »
Its like someone else said the refill and fix the seal is only a band aid. The damage has started just hope its not too bad. It wont fix the problem but maybe it will help.
April 30, 2008, 06:59:49 am
TOW'D
jumping out of gear
April 30, 2008, 06:59:49 am »
I hear ya possum
maybe replacing the seals will give more time to find a good tranny
are the ratios the same in a gasser transaxle?
thanks
hank
April 30, 2008, 07:38:19 am
Possum79
jumping out of gear
April 30, 2008, 07:38:19 am »
I dont know much about that one but I dont think they are. If the bellhousings are the same then you can use one. You can look up your tranny code at
http://www.scirocco.org/gears/
and get a code from a gasser to compare the ratios.
It doesnt have to be the same ratio but it needs to be pretty close.
General Information
jumping out of gear
