Author Topic: Performance Ideas for a top end rebuild?  (Read 4100 times)
April 21, 2008, 01:05:16 am
chrisrandle1
  • 32
« on: April 21, 2008, 01:05:16 am »
Hello; I am about to start a top end rebuild of a 1992 Jetta EcoDiesel.  I was interested in hearing some ideas on performance upgrades while the head is off.  The timing belt went so I have some valves to replace.  I will also be replacing the turbo.  I am interested in improving the stock 59 HP.
Thanks a bunch
1992 EcoDiesel - Soon to have P n P Head, T3 Turbo and more!!!
Reply #1April 21, 2008, 01:33:31 am
truckinwagen
  • 1895
« Reply #1 on: April 21, 2008, 01:33:31 am »
if you feel like living a little and taking some risks, port the head while it is off and the valves are out.
better flow means better power.
83 Opel Kadett Diesel
Reply #2April 21, 2008, 01:45:13 am
Rat407
  • 289
« Reply #2 on: April 21, 2008, 01:45:13 am »
Major improvement would be to install a new 2.5 or 3 inch down pipe and exhaust all the way back. That really woke up my 91 ECO. Also a Giles pump  mode made a big difference as well.
I like my K14, just the right amount of boost when needed for a daily driver. What other turbo where you wanting to get?
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #3April 21, 2008, 06:47:29 am
stewardc
« Reply #3 on: April 21, 2008, 06:47:29 am »
Try one of the aftermarket camshafts that PP offers, port the head, Install ARP studs and a 1.9 metal head gasket.
Reply #4April 28, 2008, 09:48:37 pm
chrisrandle1
  • 32
« Reply #4 on: April 28, 2008, 09:48:37 pm »
Hello;
Today I took the head off of my car and found that all but one of the valves had kissed the pistons when the timing belt broke.  There are also cracks between all of the cylinders along with cracks in all of the precups.  So now I am in the market for a clean complete head.
I was looking at some of the posts about the 1.9 head on the 1.6 block, sounds interesting, I just don't seem to be able to find a complete beginning to end story on it.
Anyone have a source for a complete head.  Maybe a 1.9 head if its not a nightmare.
Thanks and any info would be great.
Reply #5April 28, 2008, 10:33:00 pm
Pat Dolan
  • 163
« Reply #5 on: April 28, 2008, 10:33:00 pm »
You might also want to pull the pistons for a good look.  Often when the valves kiss, the crown of the piston distorts the ring grooves enough to seize the rings.
In other words, you may be looking for an entire used engine.
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
Reply #6April 29, 2008, 06:59:50 am
« Reply #6 on: April 29, 2008, 06:59:50 am »
Quote from: "chrisrandle1"
Hello;
Heads are available, Prothe on this board sells them. not complete though I dont think but you could get what you needed.
Reply #7April 29, 2008, 07:05:17 am
« Reply #7 on: April 29, 2008, 07:05:17 am »
Quote from: "Pat Dolan"
I agree on the pistons just replace them but I'm curious Pat, why would you suggest he replace the entire engine?
Looks like he lives in the states and turbo engines are just not that available here. Besides that he can do a easy rebuild for not to much if the bores are ok, new standard pistons with rings and a new head (or repair the current one) and off to the races, sorta speak.
Reply #8April 29, 2008, 07:17:18 am
« Reply #8 on: April 29, 2008, 07:17:18 am »
chrisrandle1
Can you get us a pic of the cracks in the precups?
The cracks in between the valves is normal unless they go DEEP..
I just remembered.
I think I can get complete heads (TD) for $850.00 + shipping.
I don't know if that's a good deal or not but it's a option I guess.
Reply #9May 01, 2008, 12:11:19 am
chrisrandle1
  • 32
« Reply #9 on: May 01, 2008, 12:11:19 am »
Hello again with some updates
Today I poured gas into each port to see how tight the valves were.  I don't know if this is a good test but the valves did not leak any of the gas.  So I am starting to think that they are not bent.  I am actually considering just putting the head back on the way that it stands.
The cracks are fine and I think they are the normal cracks that you find on these heads.  If I can get away with this I can spend money on other upgrades.
Anyone think that is a bad idea?
Reply #10May 01, 2008, 01:55:11 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #10 on: May 01, 2008, 01:55:11 am »
you want to be sure - drop the valves and make sure they arent bent - heck if they slide out easy then they must be straight.
'91 Golf Cabrio 1.9TD
Reply #11May 02, 2008, 10:45:42 pm
chrisrandle1
  • 32
« Reply #11 on: May 02, 2008, 10:45:42 pm »
So another question for you guys...how in the heck do you get these valves out.  I have a valve spring compressor that has worked for all of my other projects but there is now way it will work for this one.  Special tool?
Another question is where to find the tool needed to get the injectors out.  I read somewhere that somebody had used an extra deep 27mm, but I can't seem to find one.
Thanks in advance
Reply #12May 03, 2008, 07:46:06 am
« Reply #12 on: May 03, 2008, 07:46:06 am »
i;ve heard of sticking newer lifters in out of a newer 2.0
Reply #13May 03, 2008, 09:22:37 pm
« Reply #13 on: May 03, 2008, 09:22:37 pm »
Thanks in advance
I used the same spring compressor I bought for any engine. I used a O2 sensor socket sitting on top of the spring and compressed it, then used a magnet to remove the keepers. Reverse process to reassemble.
