will this 1.7 idea work?
Topic: will this 1.7 idea work? (Read 6293 times)
April 17, 2008, 05:32:59 pm
oldskool rich
April 17, 2008, 05:32:59 pm »
ive heard of a few people doing 1.7s and i want to hav a go.
my plan is, AAZ block, 1.6 crank (lightend/balenced), PD con rods, AAZ pistons (ceramic coated) obviously the compression ratio will be all wrong because of the shorter crank stroke.
if i cut the top off the AAZ block it would sort thing out, without buying custom rods
will this work?
f6squared I.D.S.T
April 17, 2008, 05:52:56 pm
Luckypabst
April 17, 2008, 05:52:56 pm »
How thick is the block deck vs. half the difference in stroke? Too much shaving and you'll be in the water jacket.
Longer rods?
Chris
'82 TD Westy
'81 NA Caddy
April 17, 2008, 05:58:08 pm
oldskool rich
April 17, 2008, 05:58:08 pm »
i dont know if theres enough to cut off, was hoping sumone will know, are there any stock rods that will fit?
f6squared I.D.S.T
April 18, 2008, 09:08:00 pm
rabbid79
April 18, 2008, 09:08:00 pm »
I have considered doing something like this, but with a forged 92.8mm crank out of a '93-'95 ABA. I've done some calculations, and with a 1.9 head, the compression ratio drops to around 20:1 with the stock rods and the thinnest AAZ metal head gasket available. You'd have 1.84 liter engine with a little better revving capability and still have decent torque. The compression ratio is also better suited to super-high boost applications.
'15 WRX
April 18, 2008, 09:24:37 pm
April 18, 2008, 09:24:37 pm »
low compression ratio would be great for racing applications (more boost :twisted:) as the high compression ratio was designed for great cold starting. an intake air heater would probably help out a lot for those colder starts
April 19, 2008, 05:59:31 am
oldskool rich
April 19, 2008, 05:59:31 am »
so how much should i take off the block? i would like to run mega boost but at the same time i dont want to be tring to start it up for hours each day, its still a daily driver.
i am collecting the block next week, and im gona get the top skimmed off strait away, so cud do with some advice, also is there another IDI piston that has a wider bore than the 1.9 but will take the same rods so i cud bore it out to get more torque?
f6squared I.D.S.T
April 19, 2008, 10:06:25 am
MJF
April 19, 2008, 10:06:25 am »
YouŽll have to cut the block 4mm minimum...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
April 19, 2008, 03:38:41 pm
oldskool rich
April 19, 2008, 03:38:41 pm »
ok 4mm, will that lower my compression? how much difference to stock 1.9 is that? does anyone know how wide the 5 pot pistons are? will they fit the aaz rods?
there must be somthin that will fit :?:
i was thinking that to help me start up maybe a could use a more powerfull starter motor or a 24volt battery, any sergestions?
f6squared I.D.S.T
April 19, 2008, 04:33:38 pm
Baxter
April 19, 2008, 04:33:38 pm »
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/enginedata/dsl/KYdata.htm
April 19, 2008, 04:43:52 pm
April 19, 2008, 04:43:52 pm »
Thanks for the link... this is the first time I've seen this:
Dynamic Timing AVL-bosch-Souriau-sun-VLT4139 15* +/-1* @ 900 RPM
April 20, 2008, 01:05:19 pm
Baxter
April 20, 2008, 01:05:19 pm »
One level up from last link.
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/enginedata/engine.htm
Check JX
Reply #11
April 20, 2008, 05:52:58 pm
oldskool rich
Reply #11 on:
April 20, 2008, 05:52:58 pm »
wow that is amazingly helpfull, that saves me asking about 100 questions
dont supose theres one of those data lists for every car in the world with a good seach engine? :lol:
f6squared I.D.S.T
Reply #12
April 21, 2008, 01:40:16 pm
Baxter
Reply #12 on:
April 21, 2008, 01:40:16 pm »
There is yes.
I have it at work.
Its called Autodata!
It comes on a CD now, go check e-bay, theres bound to be a cracked copy of it somewhere.
I mailny fix older cars and vans, so upto 2003 is fine for me, thats what I have, infact, no, I recently found 2006, but I have no idea where it is now or I would run you a copy off.
Reply #13
April 28, 2008, 09:13:45 am
oldskool rich
Reply #13 on:
April 28, 2008, 09:13:45 am »
ok so ive took everthing off my dona engine now, im ready to get it cut down, just not sure how much by, the differnce in stroke is 9.1mm if i wanted it to have the same CR id hav to cut that much off.
how much difference wud each mm make to the CR?
if i used a thinner gasket cud i cut less off?
i wud like sumone smarter than me to tell me how much i shud cut off and what gasket, i want it to start up fairly easy and be able to run as much boost as possible
sorry i dont want much do i :lol:
f6squared I.D.S.T
Reply #14
April 28, 2008, 09:21:33 am
Reply #14 on:
April 28, 2008, 09:21:33 am »
From what I remember of my block, I don't think you will be able to cut off enough to have a high enough CR to be able to start it. The passages start to really open up not all that far down.
