Author Topic: Is 200hp out of a 1Z unrealistic?  (Read 4119 times)
April 16, 2008, 05:39:06 pm
rallydiesel
  • 1880
« on: April 16, 2008, 05:39:06 pm »
I am gradually building up a Mk2 m-TDI with an AAZ bottom and 1Z top. Would hp above 200hp be unrealistic? If it isn't, what sort of internals should I be building with? I have heard that A4 PD pistons would be much stronger than the 1Z. Would the AAZ rods be up to that sort of power?
P.S. I know the Mk2 axles won't like the power but I am just concentrating on the engine now, the body will be upgraded after the motor is built.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1April 17, 2008, 04:22:49 am
Re: Is 200hp out of a 1Z unrealistic?
« Reply #1 on: April 17, 2008, 04:22:49 am »
Quote from: "rallydiesel"
http://vwdiesel.net/phpBB/viewtopic.php?t=11698&postdays=0&postorder=asc&start=195
read that thread... stock 1.6's with huge turbo's and intercoolers are nearly pushing 200 hp.  and the 1Z is built stronger.  bigger turbo, nozzles, intercooler and a good pump should bring you to where you want to be  :wink:
http://www.passengerdiesel.com/index.php?option=com_content&view=article&id=6:the-300-dollar-sleeper&catid=4:videos&Itemid=8
there is the vid, but it says 1.9? i thought it was a 1.6TD
