Author Topic: fuel gov mod???  (Read 2195 times)
April 16, 2008, 08:53:51 am
James8485
  • 223
fuel gov mod???
« on: April 16, 2008, 08:53:51 am »
hey i have done the boost pin mod and next i am going to try the little switch thing at the top of the pump and fuel gov mod.....when i take the switch off it says to disconect the wire 3,4 in the "make your 1.9L a faster car"  thread   well once i take the wires off is that it??? or do i attach them to somwhere else or what....i drive a crap load of highway so i think i should get better MPG!
any advise would be great!
---------James--------
Reply #1April 15, 2011, 09:51:18 am
blackbird82
  • 151
Re: fuel gov mod???
« Reply #1 on: April 15, 2011, 09:51:18 am »
the wire to the solenoid on the front of the pump, if you wire it in to your fuel shut off solenoid it will get constant power when the engine is running.
The solenoid on the front controls a bypass for the case pressure to your advance piston.
When turned on, it allows case pressure to give you advance.
when powered off it bypasses a percentage so your timing is more retarded.
They did it for emissions, so at lower power demands you have less NOx emissions.
It does have the benefit of quieter in town when light on the throttle
I found with mine, when you hardwire it. At light throttle, with the advance makes a nice nailing
I set up a boost pressure switch for mine, so when you wanna move it, timing advances and you go.
and when light coasting, under 5psi boost. It quiets things down.
Makes the seat warmer happy
Peace
I love the whistle......
