Author Topic: Transmission Flushing  (Read 4006 times)
April 12, 2008, 06:18:40 pm
subsonic
  • 1836
« on: April 12, 2008, 06:18:40 pm »
So I should be getting my 02A CTN transmission shortly.  It has about 100,000 miles on it.  While it is out and easy to get to, is there any preventative maintenace I can do on it?  Seals, lubrication etc?
Is flushing as simple as fill and drain?  I would assume that for the fill and drain to work, I would need to drive it in between, to circulate all the new fluid around.  Idea's?
Reply #1April 14, 2008, 07:04:06 pm
commuter boy
  • 277
« Reply #1 on: April 14, 2008, 07:04:06 pm »
I usually drain, fill, drive, drain again and re-fill.  I always jack the car up on the filling side so that it gets a wee bit of extra oil.
Reply #2April 14, 2008, 07:08:11 pm
« Reply #2 on: April 14, 2008, 07:08:11 pm »
if you could somehow insert something into the drain hole (thread a hose in maybe?) then you could easily 'flush' the tranny with a little pump circulating the fluid back into the tranny.  of course you would want something that would clean it out as best as possible, and have a filter attached so crap doesn't flow back into the tranny.  not really sure how they flush automatic trannies, and what kind of solutions (if any) they use.
