Author Topic: 1.6 and 1.9 con rod dimensions  (Read 3071 times)
April 12, 2008, 12:24:17 pm
smiffie88
  • 29
« on: April 12, 2008, 12:24:17 pm »
i want to use 1900 pistons in my 1600 gtd motor as it needs a re-bore gudgeon pin looks bigger on the1900 rod i need the dimensions off both rods so i can try and find a rod that is already made as custom rods seem to be expansive.
ryan
Reply #1April 12, 2008, 02:26:52 pm
MJF
  • 581
« Reply #1 on: April 12, 2008, 02:26:52 pm »
1,6: 24/136/50,6mm
1,9na: 24/150/50,6mm
1,9td: 26/144/50,6mm
small end/length/big end
1,9na piston is with 24mm pin and it is a couple mm shorter than 1,6 piston.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2April 14, 2008, 04:05:44 am
oldskool rich
  • 446
« Reply #2 on: April 14, 2008, 04:05:44 am »
is that you ryan? hows it gwarning
what rods are you running MJF? did you have them made?
cant you get a 1.7 transporter engine? is that the same bore as the 1.9 im guessing?
im a little confused with all these bores, strokes and rods, how did yours come to be a 1.7? do you have a 1.6 crank?
f6squared I.D.S.T
Reply #3April 14, 2008, 07:33:33 am
MJF
  • 581
« Reply #3 on: April 14, 2008, 07:33:33 am »
Quote from: "oldskool rich"
I have custom fitted Nascar SBC rods (~154mm long). I´m also using 1,9 block (80mm bore) and 1,6 crank. 1,7 have same bore than 1,9 and same connecting rods and crank than 1,6
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #4April 14, 2008, 01:06:59 pm
oldskool rich
  • 446
« Reply #4 on: April 14, 2008, 01:06:59 pm »
Quote from: "MJF"
how much did those rods set you back if you dont mind me asking?
so if you ran a 1.6 crank and rods in a 1.9 and cut a bit off the top of the block ud have a 1.7?
i wana start building a new engine for when this one gives up, i want a 1.7 but dont know how to go about building it. do you think that its worth getting rods made up? or wud standard rods take that sort of horse power
f6squared I.D.S.T
Reply #5April 15, 2008, 01:48:45 pm
smiffie88
  • 29
« Reply #5 on: April 15, 2008, 01:48:45 pm »
wot up rude boy     its ryan
thanks for sizeswill be looking for stock rods from another car if vw dont make an engine that uses ones which are the right size
custom rods cost to much controlled bodging is the way forward
