Author Topic: How can I tell if AAZ has wobble without running?  (Read 4988 times)
April 10, 2008, 09:19:37 pm
rallydiesel
  • 1880
« on: April 10, 2008, 09:19:37 pm »
I am looking at an AAZ block from a guy but the head is off. How can I tell if the crank has the wobble issue without running the engine? Does the crank pulley actually has play to it if I move it by hand? If the crank gear is off is there any way to tell? How much should I expect a local machine shop to charge to machine the crankshaft to a TDI gear (with the crank out)?
How much would you guys pay for an AAZ block, crank and rods?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1April 10, 2008, 10:22:45 pm
« Reply #1 on: April 10, 2008, 10:22:45 pm »
you can tell with the crank gear removed, you'll see that the slot is worn on the edges.
