Author Topic: aaz under fueling, has anyone heard of this?  (Read 2725 times)
April 09, 2008, 03:35:56 pm
oldskool rich
  • 446
« on: April 09, 2008, 03:35:56 pm »
ok i believe ive found the cause of my stalling trouble, my local vw specialist told me that its definatly not mechanical, and so it has to be down to fuel.
my pump is a bit nutty, boost pin is extreamly modified, also 11mm pump piston, gov mod and omfg does it smoke, if i punch the thottle it fills the street with smoke, wen i cum on boost around (40psi atm) i believe the pump is chucking in more fuel than the centrifugal pump can suck into the pump Reservoir. so wen i cum off the gas it stalls, and wen im on the gas its slowing me down.
has anyone cum across this before? does anyone run an electric fuel pump to prevent this, TDIs do dont they
f6squared I.D.S.T
Reply #1April 09, 2008, 04:09:04 pm
  • 1739
« Reply #1 on: April 09, 2008, 04:09:04 pm »
TDI's don't have an extra pump. PD's have a mechanical pump on the head  to the feed the line and some may have a lift pump in the tank. Maybe your fuel demand is so high you are emptying the line and filter so that when it's time to get back on the throttle there's no fuel left. I have a similar problem with older GM 6.2 and 6.9's running on VO. If i don't put in an extra lift pump they will run fine until i lift off and then when i get back
on the pedal it'll stall.
Reply #2April 09, 2008, 04:27:07 pm
oldskool rich
  • 446
« Reply #2 on: April 09, 2008, 04:27:07 pm »
safe, ill get me a pump tomoz
im drag racing the old caddy at the wkend so i want as much power as possible dont wana stall b4 i reach the end :roll:
f6squared I.D.S.T
Reply #3April 09, 2008, 04:55:38 pm
Re: aaz under fueling, has anyone heard of this?
« Reply #3 on: April 09, 2008, 04:55:38 pm »
Quote from: "oldskool rich"
i think you have a good theory right there...  if i were you i would get a gauge put on the out port of the pump.  would be interesting to know what psi levels when the pump is screaming  :twisted:
Reply #4April 09, 2008, 05:58:28 pm
oldskool rich
  • 446
« Reply #4 on: April 09, 2008, 05:58:28 pm »
Quote from: "jtanguay"
where cud i get a gauge to measure that?
the AFN pump that i took my pump piston & head off produced 22,306psi according to bosch :shock:
f6squared I.D.S.T
Reply #5April 10, 2008, 12:18:45 am
bert
  • 423
« Reply #5 on: April 10, 2008, 12:18:45 am »
try a low pressure facet feed pump,cheap on ebay,will help feed that hungry pump  :wink:  whwrw you taking it the weekend bert? or shall i look for smoke signals  8)
Bert
Reply #6April 11, 2008, 07:46:53 am
oldskool rich
  • 446
« Reply #6 on: April 11, 2008, 07:46:53 am »
OMFG ive just used a pump off a polo carb and it works amazingly well, no stalling or annoying flat spots, very smooth. i was very suprised it worked, deep down inside i never thort for one second it wud.
i love it wen a plan comes togeather 8)
this weekend ill be at santa pod (spring fest)
my truck is running better than ever before, im confident it shud eat sum vr6 hopfully :twisted:
every time i drive it it puts a little smile on my face, you know the kind that you cant get rid of. and wen i get out my hands are all shaky and sweaty :oops:  is it wrong to feel this way about a car?
f6squared I.D.S.T
