Author Topic: 228mm VR6 upgrade kit. G60  (Read 5039 times)
April 07, 2008, 03:44:37 pm
subsonic
  • 1836
« on: April 07, 2008, 03:44:37 pm »
So it looks like I will be picking up a 02A TDI tranny for my project.  I will be staying with a mechanical cable clutch setup.  Do I understand correctly that I can upgrade this setup with a 228mm VR6 pressure plate and clutch setup? This does not have the dual mass flywheel.
Reply #1April 08, 2008, 09:24:32 am
subsonic
  • 1836
« Reply #1 on: April 08, 2008, 09:24:32 am »
Called about a g60 flywheel today, parts guy asked me which one I wanted.  Didnt know there was more than one kind.  Needs to fit a 02A TDI tranny and be able to mount up to a VR6 clutch kit.  Anyone have the answer?
Reply #2April 08, 2008, 10:00:08 am
MJF
  • 581
« Reply #2 on: April 08, 2008, 10:00:08 am »
What I know, rare Rallye fw is lighter than normal. Normal fw is 028105269B or 028105269BX as far as ETKA says. My fw had different number, but canīt find the picture :? Same flywheel is used with 2,0 4-cylinder Volkswagens. :!:
Edit: Found the pic, fw is from ī91 Passat with 2E engine.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3April 10, 2008, 08:30:23 am
myke_w
  • 1099
« Reply #3 on: April 10, 2008, 08:30:23 am »
the flywheel you want is from g60, clutch and PP need to be from vr6 like you have stated..
http://www.mjmautohaus.com/catalog/product_info.php?products_id=401
is the sickest deal I've ever seen on them.. FYI you want the Sachs *** not the Valeo.. rated for higher power.. One drawback, the flywheel is lighter, you can read all about pros and cons of that for yourself though.. I say go for it..
Reply #4April 13, 2008, 04:23:12 pm
subsonic
  • 1836
« Reply #4 on: April 13, 2008, 04:23:12 pm »
I had seen that link before.  Your right, that is a very good deal.  As a matter of fact, I liked it so much I went ahead and ordered one today! :)
Should be here by Friday.  I am good with the 14 pound g60 flywheel.  I am guessing you were talking about chatter when you were talking about the possible downside to the lightened flywheel.  This one will still be heavier than the lightened 210 I was going to use if I stayed with a 020 trans.  Stock is supposed to be 22 pounds,  This one will be 8 pounds lighter.  I am hoping that the weight reduction will help with throttle response.  I think at 14 pounds it will still be heavy enough for good highway cruising.
Of course the real reason I like this setup is holding power.  No slippage under full power :twisted: / gear jamming :twisted:  / 30psi boost action! :twisted:
Reply #5April 13, 2008, 04:35:31 pm
  • 1739
« Reply #5 on: April 13, 2008, 04:35:31 pm »
anything to get away from that stupid dual mass FW
Reply #6April 16, 2008, 01:09:40 pm
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
« Reply #6 on: April 16, 2008, 01:09:40 pm »
Stock weight flywheel is 21 lbs. 0.8 oz. And yes, that's the kit that will work great in your car.
Good luck!
-BB
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
