Author Topic: G-Teched my 1.6TD - Baseline Runs  (Read 106398 times)
Reply #105July 07, 2005, 03:05:59 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #105 on: July 07, 2005, 03:05:59 pm »
Quote from: "Mark(The Miser)UK"
Ha,
I get sad when I wear a tyre [tire]? out :shock:
That just reminded me; the Golf's front tires are almost bald :).  I'm thinking of replacing the current steelies with new wheels; 15x6.5" or 15x7.0" Rota Slipstreams, which are somewhere from 11 to 13 pounds each (without tire). Low price, too. Winter tires will go on the steelies later for cold season.
O-ringing is a little more difficult to find than I thought. Dave went to BD Power today (www.dieselperformance.com) and they said hardly anyone has o-rings small enough for a 1.6TD block because the bores are unusually small. A couple other machinists we contacted also do not have the proper size o-rings.
It seems that this may be more hassle than it's worth. The metal 1.9L headgasket and Raceware headstuds should be fine with 26-30 PSI of boost.
So now the block is going back to the machinist today or tomorrow to get the bores, etc. done ASAP. Hopefully it'll be done by Friday so Dave can start reassembling the block this weekend.
Stiffer HD valve springs are being ordered @ Techtonics Tuning for the 1.9L head.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #106July 19, 2005, 09:44:30 pm
Josh
  • 54
Doesn't a hydraulic head rob a significant amount of power?
« Reply #106 on: July 19, 2005, 09:44:30 pm »
Hey all,
  Doesn't a hydraulic head consume a significant percentage of power?  As I recall, most folks interested in performance TD tuning go for a mechanical head.
  But I've not been around for a while; has this idea been refuted?
  Thanks,
    -Josh
'84 Quantum sedan (oops, not '83!)
'83 Quantum wagon(ditto, not '82)
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #107August 07, 2005, 06:06:23 pm
  • 1156
« Reply #107 on: August 07, 2005, 06:06:23 pm »
Raised RPM (governor) = windage tray for this TD motor:
1.6L and 1.9L heads, the latter is disassembled:
New oil squirters:
The block:
The block's already fully assembled now but I did not have the camera with me at the time. Raceware con rod bolt/nut kit included.
These cars are getting lonely:
Dave's MK1 Caddy that will be PD130 TDI equipped:
The 1.9L 8v PD130 engine we picked up at Vancouver Intl. Airport (shipped from Europe):
These pictures are at least a few weeks old. I'll take more pictures of my TD in its current state when I can.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #108August 11, 2005, 09:12:15 am
fspGTD
  • 1529
« Reply #108 on: August 11, 2005, 09:12:15 am »
Lookin' good mark!  Can't wait to see how this turns out...
PS - You might be thinking about using those H-beam rods like from the 240 hp caddy about now, eh?  :wink:
Jake Russell
Reply #109August 11, 2005, 09:43:33 pm
  • 1156
« Reply #109 on: August 11, 2005, 09:43:33 pm »
Quote from: "fspGTD"
Thanks and yes I'm tempted to buy upgraded rods and have the pistons ceramic coated, and so on, but the budget and time constraints won't allow them. Anyway I'll be happy to have the peak power/weight ratio of a VR6 (approx. 140whp in my case).
It's said that OEM 1.6TD rods will break at above 290lb-ft. My OEM rods are shot-peened but I'm not exactly sure how much of a difference it makes. Raceware con rod bolt/nut kit included. If I can make 250lb-ft @ wheels @ 4,250 RPM, then 200whp is achieved and I'll be very surprised! Honestly though, as long as it's fun to drive and gets me somewhere, I'll be happy :)
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #110August 11, 2005, 09:47:54 pm
  • 1156
« Reply #110 on: August 11, 2005, 09:47:54 pm »
I have a custom air/water intercooler. It was originally for my 1.9L TDI engine that I recently sold:
I may choose the air/water instead of the aforementioned air/air FMIC by Precision Turbo & Engines. The air/water intercooler has the following advantages:
1) Far easier IC plumbing from turbo to intake manifold, composed of two straight steel pipes and some silicone connectors. Less fabrication work means my Golf will be back on the road sooner.
2) Stealth factor.
3) Shorter plumbing and smaller intercooler core = significantly less internal volume = slightly faster pressure/boost response.
4) Possibly more efficient cooling than a FMIC for short power bursts, which is typical of most people's (incl mine) driving style. Includes 1/4 mile drag racing, which ice-loading may be useful.
If heat soak is ever an issue, i.e. during a long and hard highway race (I rarely do this), simply adding more water or installing a larger radiator will reduce that. In other words, this is a more scalable system than a FMIC.
Today I just rolled over 400,000km in my girlfriend's 1984 Volvo, which still runs great:
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #111August 11, 2005, 09:48:30 pm
  • 1156
« Reply #111 on: August 11, 2005, 09:48:30 pm »
Here's a rather crude photoshop of the charge air path:
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #112August 11, 2005, 09:52:48 pm
  • 1156
« Reply #112 on: August 11, 2005, 09:52:48 pm »
In case I forgot to mention, I also have the SDI intake manifold pictured above.
A TDIClub.com member with the same SDI intake reported having a boost leak in the upper black portion (plastic) at 18 PSI. Note the blue sealant on the sides of the black intake in the previous post.
So this will likely be a temporary intake. Four mandrel bent metal runners & a pressure box (cylinder) may replace the plastic upper portion once I'm ready to turn up the boost. Velocity stacks in the pressure box would be nice, too.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #113August 12, 2005, 05:49:56 pm
vwmike
  • 1158
« Reply #113 on: August 12, 2005, 05:49:56 pm »
So, what exactly is the difference between the PD 100, PD 130, and the PD 150?
Reply #114August 13, 2005, 01:55:26 am
Maarten
  • 339
« Reply #114 on: August 13, 2005, 01:55:26 am »
Turbo, injectors, ECU and with the PD150 strenghtened rods and pistons.
Do I read correctly that you use the 1.9 head (from a AAZ engine or?) on the 1.6? I thought a 1.6 head has better proportioned exhasut valves compared to the 1.9?
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #115August 13, 2005, 06:49:19 am
QuickTD
  • 1156
« Reply #115 on: August 13, 2005, 06:49:19 am »
 I helped finish the installation of Daves (TDImeister's) SDI manifold. The boost leak actually turned out to be at the junction between the aluminum part of the manifold and the head. The SDI manifold interfered slightly with the TDI exhaust manifold. Because of this the manifold was not pulled in tight against the head and there was a leak at the manifold gasket. The plastic part of the manifold did not actually leak. The blue silicone was put on there to assist in finding the original leak. With the manifold "clearanced" a bit the problem was solved.
 I'm not sure how much boost the SDI manifold would withstand. Although it didn't leak in Daves car, having seen it, I don't think I would trust it with more than 25 psi. Good intercooling would likely be instrumental in helping the plastic manifold survive.
Reply #116August 13, 2005, 09:08:54 am
fspGTD
  • 1529
« Reply #116 on: August 13, 2005, 09:08:54 am »
Those long runners should help get a big turbo up and going sooner, but I don't think the lower portion of that manifold will fit in a 1.6lTD, with the stock turbo position being so high and close to the head.  I hope you can make it work!
Jake Russell
Reply #117August 13, 2005, 05:39:39 pm
  • 1156
« Reply #117 on: August 13, 2005, 05:39:39 pm »
Thanks for the details, QuickTD! Good to know.
Maarten, that is true.. stock for stock I'd likely save the money and keep the 1.6L head, but if modifying the head (including porting), I believe the AAZ version has better potential. The AAZ has larger valves too.
fspGTD: This is the GT20 turbo + modified ATP 8v exhaust manifold that's going on the TD:
It sits quite further back; I may or may not have to modify the firewall like I did to my 1989 Jetta coupe that had the 1.9L ALH TDI:
I'll want enough clearance to place a heatshield to hide the hammer marks :P
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #118August 13, 2005, 09:22:57 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
« Reply #118 on: August 13, 2005, 09:22:57 pm »
Why did you have to modify the firewall? Were you using the VNT-15 or something different? The reason I ask is because I'm doing the ALH swap into my 89 Golf and will be clocking the turbo up like yours was. I'll be using the stock turbo that comes with the engine (might update to the VNT-17 later).
I'm hoping to not have to do that to mine if possible.
Reply #119August 14, 2005, 12:24:00 pm
935racer
« Reply #119 on: August 14, 2005, 12:24:00 pm »
The pd 130 and 150 are the same except for ecu and turbo. I will might have to mount marks turbo upside down to clear the intake manifold. I am litereally int he middle of port matching and polishing the intake to the head, and the exhaust manifold as well. The actual port design on the 1.9 head is a lot better and the intake side is much larger. However the exhaust on the 1.9 almost seems smaller, by like a mm. But to match the exhaust maniold I'll be taking that much out anyways. The head will be going to the machine shop tomorrow to get the valve seats ground and a couple other goodies. Hopefully it wqill be back at the shop here by wednesday or so and than I can reassemble the head with the heavy duty valve springs and race ware headstuds and 1.9 metal head gasket. Than A custom grind a colt cams and I'll throw the pump on and all the other powdercoated goodies and it will be rockin. Especially witht he 4 puck cluytch and 6 pound flywheel!
