setting thrust bearing end play?
Topic: setting thrust bearing end play? (Read 1977 times)
March 28, 2008, 08:16:16 pm
ezekiel
March 28, 2008, 08:16:16 pm »
so, I'm starting assembly on my engine, and the standard sized thrust bearings (6-piece) are too big, is it NORMAL to have to flat-sand/grind them into spec? The crank was only polished, wasn't ground.
thanks
--Justin
