Author Topic: part compatibility  (Read 6824 times)
March 21, 2008, 03:03:47 pm
smoken u
  • 231
part compatibility
« on: March 21, 2008, 03:03:47 pm »
was just wondering if any parts from a 1.8L Gasser will work on the 1.6, cause I got one for free, that runs from a parts car at school.
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1March 21, 2008, 03:24:40 pm
upchuck
  • 41
part compatibility
« Reply #1 on: March 21, 2008, 03:24:40 pm »
i used a GLI dual exhaust mani and downpipe (for an n/a) for a bump in exhaust flow.  i've also heard some gasser intakes give better airflow too but not sure which ones.
Reply #2March 21, 2008, 04:34:05 pm
smoken u
  • 231
part compatibility
« Reply #2 on: March 21, 2008, 04:34:05 pm »
I've heard about the gasser intakes, they are more open and have seperate runnersfor each intake port, but I was wondering about some internals, like the crank and conrods but even if they fit do they have the strength to handle the cylinder pressures of a Diesel?
pistons and head are no good cause they're too thin and low compression.
Reply #3March 21, 2008, 08:59:16 pm
upchuck
  • 41
part compatibility
« Reply #3 on: March 21, 2008, 08:59:16 pm »
the engine builder who did my bottom end was working on building a 1.9 diesel bottom end by boring and sleeving a 2.0 block.  i haven't followed up yet to see how it worked and have no idea what parts he was using, but he seemed enthused about saving some coin (since diesels are rare and pricey around here) it was going to be for his project daily driver rabbit truck.
Reply #4March 21, 2008, 09:09:08 pm
TedV
  • 182
part compatibility
« Reply #4 on: March 21, 2008, 09:09:08 pm »
1.8 crank n rods are different.  think about the only long block parts you can use on both, cam cover, maybe intermediate shaft seal holder (intermediate shafts are different), oil pan if you have an NA diesel, valve shims if you have a mech lifter motor.  front and rear crank seal holders, sheet metal between the motor and trans some nuts and bolts
Reply #5March 22, 2008, 04:04:59 am
smoken u
  • 231
part compatibility
« Reply #5 on: March 22, 2008, 04:04:59 am »
filter mounts are identical too, the oil cooler just threads on to it.
Reply #6March 23, 2008, 02:35:12 am
Baselyne
part compatibility
« Reply #6 on: March 23, 2008, 02:35:12 am »
that plastic oil cam saver thing
dont forget to robb the motor mounts
hardware of all kinds
gas starter works on summer but cant turn in winter diesel
rads fine if you watch it,  diesels suppose to be different one
should be a better alt on gti;s
larger oil pump too
if it's gti then there is a nicer trani and clutch package 210mm
Reply #7March 24, 2008, 06:01:52 am
smoken u
  • 231
part compatibility
« Reply #7 on: March 24, 2008, 06:01:52 am »
no,its not a GTI, just the EFI 1.8L,
will the oil pump still work though?
Reply #8March 26, 2008, 11:29:51 am
Baselyne
part compatibility
« Reply #8 on: March 26, 2008, 11:29:51 am »
Id look into that oil pump, taking the pan off is easy as...
then you have two bolts holding on the oil pump, just to be sure id give it a go because maybe you have the 36mm oil pump
I was thinking that the gasser oil pumps got a different length shaft
I beleave the shafts are interchangeable but I think the gears are different size... someone to clear this up?
give it a try...rob everything you see off it
