1.6 Turbo pistons in NA motor, will it work?
Topic: 1.6 Turbo pistons in NA motor, will it work? (Read 2775 times)
March 04, 2008, 07:23:13 am
overdrivegear
March 04, 2008, 07:23:13 am »
Will 1.6 turbo pistons work in a NA engine? The only difference I know of is that the turbo pistons have notches for oil cooling but as far as wrist pin height, crown, compression ratio, etc. I think they are the same as the regular 1.6 NA pistons.
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
March 04, 2008, 08:01:44 am
subsonic
March 04, 2008, 08:01:44 am »
They should as far as I know. If you are planning on adding a turbo it could not hurt. They are suppossed to have a hard anodized surface.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
March 04, 2008, 09:15:07 am
myke_w
March 04, 2008, 09:15:07 am »
it's a direct fit.
March 05, 2008, 09:29:40 pm
Torchd
March 05, 2008, 09:29:40 pm »
Will 1.9TD pistons fit into a 1.6NA?
March 06, 2008, 01:54:30 am
MJF
March 06, 2008, 01:54:30 am »
No, 1,9 have 3mm larger bore.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
March 06, 2008, 02:22:50 am
Torchd
March 06, 2008, 02:22:50 am »
hmm... if we increase the bore and everything... is the wrist pin and stroke same?? what will i have to do to fit it?
thanks!
March 06, 2008, 06:57:25 pm
subsonic
March 06, 2008, 06:57:25 pm »
1.7 KY
