Author Topic: Looking for a 1.6 NA injection pump diagram  (Read 6200 times)
March 02, 2008, 08:22:19 pm
upchuck
  • 41
« on: March 02, 2008, 08:22:19 pm »
My IP started pissing all over the engine the other day.  With over 200k miles, and having run bio-D and the new ultra low sulfur fuel I think it's time to replace all my seals (with viton of course).  Does anyone know where I can find an exploded view diagram or something to help me along?
Thanks very much for any help!
Reply #1March 02, 2008, 09:13:04 pm
Reply #2March 03, 2008, 07:50:18 am
Baselyne
« Reply #2 on: March 03, 2008, 07:50:18 am »
ahhh thanks so much for that.. Vince
This is very useful infoz
Reply #3March 03, 2008, 08:16:54 am
upchuck
  • 41
« Reply #3 on: March 03, 2008, 08:16:54 am »
Wow, Thanks Vincent!
...and yikes, that looks pretty intimidating on first glance :shock:
Reply #4March 03, 2008, 08:30:24 am
Baselyne
« Reply #4 on: March 03, 2008, 08:30:24 am »
soooo intimidating on first glance
Reply #5March 09, 2008, 04:46:55 pm
upchuck
  • 41
« Reply #5 on: March 09, 2008, 04:46:55 pm »
when doing my research on this site for this pump reseal or rebuild job, i came across this bit of gold:
http://vwdiesel.net/phpBB/viewtopic.php?t=4353&highlight=injection+pump+rebuild
however, the post contains cautions that certain procedures are glossed over and special tools and equipment are needed to do the job right and are not mentioned!?
is anyone here able to advise as to what special tools would be needed and what procedures are left out of this diy guide?  i already have read about the special tool for the 3 sided bolts and the instructions to mark the following:
 "take pictures of the damn throttle springs,  mark the position of the throttle shaft on the throttle arm, measure the protrusion of the governor shaft (the one with the reverse threads), measure the protrusion (or count the turns) on the main fuel screw,  note the alignment of the main cam plate... specifically the pin that drives the distributor shaft... and put it back the way you found it... can easily get it 180 degrees off... use the keyway on the main shaft as a reference" (from vincent waldon's contribution to linked post above)
also, i already have and know how to use the cam and pump timing special tools for once the pump is back together.
thanks in advance for any help!!! :D
