Author Topic: OIL GALLEY PLUGS  (Read 9780 times)
March 02, 2008, 03:53:26 pm
dillenger1
  • 777
OIL GALLEY PLUGS
« on: March 02, 2008, 03:53:26 pm »
Does anyone know where to get these online?Maybe i should try autozone,but i dought "seriously"doubt they can get them.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1March 02, 2008, 06:44:52 pm
rallydiesel
  • 1880
OIL GALLEY PLUGS
« Reply #1 on: March 02, 2008, 06:44:52 pm »
http://www.bestpricecarparts.com/
I use this one and haven't had any problems. The oil galley plug is the same as the freeze plugs (on the 1.6).
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 03, 2008, 03:00:17 am
dillenger1
  • 777
OIL GALLEY PLUGS
« Reply #2 on: March 03, 2008, 03:00:17 am »
No its not the same.The oil galley plugs cant be more then a 1/2 inch in diameter.I looked their they dont have them
Reply #3March 03, 2008, 06:25:53 am
rallydiesel
  • 1880
OIL GALLEY PLUGS
« Reply #3 on: March 03, 2008, 06:25:53 am »
Oh, I thought you meant the plug in-line with the intermediate shaft by the oil filter.
Reply #4March 18, 2008, 08:27:50 am
rallydiesel
  • 1880
OIL GALLEY PLUGS
« Reply #4 on: March 18, 2008, 08:27:50 am »
You probably found some already but here is an on-line source:
http://techtonicstuning.com/showpart.asp?partnum=103.120
Reply #5March 20, 2008, 07:50:22 pm
hillfolk'r
  • 1532
OIL GALLEY PLUGS
« Reply #5 on: March 20, 2008, 07:50:22 pm »
Quote from: "dillenger1"
the oil galley plugs are 14 or 15mm i cant remember
dont use anything but vw plugs,i used cheapo rebuild plugs
and the galley plug in the bellhousing area  leaked and ruined my 400$$ clutchnet red clutch
Throttle cables ftw
Reply #6March 21, 2008, 05:52:16 am
myke_w
  • 1099
OIL GALLEY PLUGS
« Reply #6 on: March 21, 2008, 05:52:16 am »
there's really no good reason to remove any of the plugs on the motor except the coolant freeze plugs anyway, but if you already did, libby's way is best
Reply #7September 03, 2011, 10:35:01 am
  • 2931
Re: OIL GALLEY PLUGS
« Reply #7 on: September 03, 2011, 10:35:01 am »
I started up a rebuilt engine and oil was pooring from the timing belt area.
 I found the oil galley plug was pushed out.
 Well it looks like I have good oil pressure but now I need an oil galley plug.
 I've found a good link on here to the TT store but it doesn't mention the size.
 I measured the old one and got .536"
 Converts to about 13.6mm
 Suppose a 15mm plug would do it?
 Anyone know the proper size?
Found a thread on the vortex that said they were supposed to be 14.25:
http://forums.vwvortex.com/showthread.php?5002717-Blew-the-freekin-oil-galley-plug&p=73366776#post73366776
 ,.. that was in the 16V fora but should be accurate for our diesels.
« Last Edit: September 03, 2011, 10:52:34 am by fatmobile »
Reply #8October 03, 2012, 08:22:29 pm
hillfolk'r
  • 1532
« Reply #8 on: October 03, 2012, 08:22:29 pm »
Well,15mm was for my ahu,but i got a feeling most others are the same.
generic plugs arent deep or thick enough...i had to buy a box of 5 or 10 at the dealer..
if ya want,i should be goin to my shop tomorrow night and can get ya the vw # i used
Throttle cables ftw
Reply #9October 03, 2012, 09:52:47 pm
Big Daddy Roth
  • 298
« Reply #9 on: October 03, 2012, 09:52:47 pm »
I drill the hole and thread a brass plug in
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #10October 04, 2012, 09:31:06 am
« Reply #10 on: October 04, 2012, 09:31:06 am »
BEST
IDEA
EVER..
Reply #11October 14, 2012, 09:28:39 am
hillfolk'r
  • 1532
« Reply #11 on: October 14, 2012, 09:28:39 am »
Yea look closely in the hole..theres a drilled oil hole like 10mm deep inside the hole.
dont push the freeze plug in too far and block the oil hole.
im sure bad things would happen...same with drilling and tapping it,dont tap it too deep and block the oil hole when you thread it in.
Imo,theres not enough depth to tap it without getting into the oil hole.
study the oe plug,its shorter,thicker than any cheapo replacement.
even though i had to get a box of 5 or 10 from the dealer,it wasnt more than 15$...cheap enough to allow some waste i think as far as having extras you never use :)
Throttle cables ftw
Reply #12October 14, 2012, 11:42:04 am
« Reply #12 on: October 14, 2012, 11:42:04 am »
Yea look closely in the hole..theres a drilled oil hole like 10mm deep inside the hole.... dont push the freeze plug in too far and block the oil hole.
I rekon that hole is the supply to the IM shaft bearing. The oil gallery plug is right in line with the opening in the IM bearing boss.
Reply #13October 14, 2012, 12:05:35 pm
« Reply #13 on: October 14, 2012, 12:05:35 pm »
ETKA says 14mm and that's what I've used for 1.6 or 1.9 engines prior to ALH.  I've gotten the plugs from my local machine shop and they have worked without any issue.
Reply #14October 15, 2012, 10:49:23 am
  • 2931
« Reply #14 on: October 15, 2012, 10:49:23 am »
I eneded up using a 9/16" plug from O'reily's,
 worked great and was very close to the 14mm ones I ordered.
