Guys great forum, keep it up. I have a Polo Classic (marketed in Europe as a Seat Cordoba) gasser which I intend to convert to diesel. The IDI motors available locally are all imported ex Europe and Japan, therefore parts are not easy to come by.Originally looking for 1.6 TD ( RA or SB but not available ) there were a few JR an MF imported but these seem to have gone scarce, currently can get AAZ 1.9 TD. Has anyone fitted 1.6TD turbo and injection pump on a AAZ , can this be done and will it work? Anyone done this before? Want to get approx 120 HP out of the motor
I wana use AAZ block with MF head, turbo and IP..... Andrew said compression ratio will be too high?/ does that mean it cant be done?? any way of lowering the CR??And i wana run a straight exhaust pipe... 3 inches... is it possible in an mkII... and where is it suppose to start from??? right from the turbo, from that plate with 4 bolts which mounts on to the turbo.. or does it start after the "C" exhaust clamps...??
