Author Topic: Valves, oil pump, ARP studs?!  (Read 4562 times)
February 26, 2008, 07:14:30 am
Torchd
  • 372
« on: February 26, 2008, 07:14:30 am »
Hey guys!!
Im new to this foum... i just needed sum info on a few things!
will 1.6NA(ME) and 1.6TD (MF) have the same engine valves and oil pump if both the engines have hytraulic lifters??
and which ARP head studs will fit my 1.6TD...  can sum1 give me the part number and an address in uk and canada??
Thanks!! :)
Reply #1February 26, 2008, 07:18:48 am
« Reply #1 on: February 26, 2008, 07:18:48 am »
ARP part #s
Head Studs..........................251-4701
Main Studs...........................204-5402
Con Rod bolts 1.6 and 1.7......104-6002
Trans ring gear bolt kit 020 ...204-3001
Oil pump bolts.......................661-1014
 I assume the head stud # is the 12mm stud. Some 1.6's had 11mm I guess.
Reply #2February 27, 2008, 11:31:40 am
fastvicar
  • 154
« Reply #2 on: February 27, 2008, 11:31:40 am »
Correct, early '81 1.6L had 11mm Allen-head bolts.  Supposedly the gassers' ARP kit will work with them.  I'll find out in a few days.
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #3March 03, 2008, 11:32:44 pm
Torchd
  • 372
« Reply #3 on: March 03, 2008, 11:32:44 pm »
Thanx guys!!
SO how do i find out which head bolts do i have in my car... 11mm or 12 mm???
Its 1.6 TD (MF engine code) 1988 year....
and which is the best place to get the ARP studs if im in Brimingham UK??
Reply #4March 04, 2008, 08:42:47 am
AdAm84
« Reply #4 on: March 04, 2008, 08:42:47 am »
When did they change to 12mm. I have an '84 1.6n/a. So which would it be?
Reply #5March 04, 2008, 11:35:59 am
MJF
  • 581
« Reply #5 on: March 04, 2008, 11:35:59 am »
Quote from: "fastvicar"
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6March 05, 2008, 09:49:55 am
Baselyne
« Reply #6 on: March 05, 2008, 09:49:55 am »
I was told 1.5's had 11mm and any 1.6's went with 12mm
we need to clear this kinda thing up before someone get burned on shipping and re-stocking fees
Reply #7March 08, 2008, 12:31:52 am
Torchd
  • 372
« Reply #7 on: March 08, 2008, 12:31:52 am »
Quote from: "jimfoo"
ARP part #s
The partnumber for the head studs u provided doesnt exist.....  what i can find is 204-4701.. and they are for 1.8L-2.0L 8V jetta... are those the ones??  maybe u got a typo there...  leme knw!
http://www.alamomotorsports.com/arp/hsvolkswagen.html
http://arp-fasteners.com/Catalog/Catalog.html ( will have to download the catalogue)
Reply #8March 08, 2008, 05:44:41 am
« Reply #8 on: March 08, 2008, 05:44:41 am »
Maybe you aren't looking hard enough. I get plenty of hits for 251-4701 using google, even from ARP's own web site. It's even listed in your link above, well the second link at least. I'll give you a hint, you aren't looking for them under VW.
Reply #9March 10, 2008, 03:44:24 am
Torchd
  • 372
« Reply #9 on: March 10, 2008, 03:44:24 am »
If u RECHECK in the ARP catalog.....  the part number says 204 in the catalog ...  NOT 251..(4701) remaining the same...
and i just did a google search for 251-4701.... and only MJM autohaus says they are for vw 1.6 diesel...all the other results say they are for some ford cosworth...
and i did a 204-4701 google search and it says.. this part number is for arp studs for 1.8L 2.0L 8V golfII...
so whci ones am i suppose to go forrr??
Reply #10March 10, 2008, 07:14:16 am
« Reply #10 on: March 10, 2008, 07:14:16 am »
Ford Cosworth. 251-4701 If you are worried, that's what I have installed in my engine. The cheapest place when I got mine was Summit Racing.
Reply #11March 10, 2008, 11:19:12 pm
Torchd
  • 372
« Reply #11 on: March 10, 2008, 11:19:12 pm »
Hmm thanks..
so if i order the 251-4701.... i will get it as a kit rite??  like i will not need anything else to install them??
and will i be able to use them in a 1.9TD (aaz)??  i heard they are the same 12mm in the 1.6 and the 1.9?
Reply #12March 11, 2008, 06:57:50 am
« Reply #12 on: March 11, 2008, 06:57:50 am »
You get the studs, the washers, and nuts, and even some of their lube. The only thing you need is an allen wrench to put them in the head. Good in 12 mm 1.6 and AAZ blocks.
Reply #13March 12, 2008, 08:18:02 am
Torchd
  • 372
« Reply #13 on: March 12, 2008, 08:18:02 am »
hmm.... thanx loadzzz man!!
one of my friends is gettin em tomorrow!!
Reply #14May 24, 2008, 02:05:29 am
Mechanic
  • 2
« Reply #14 on: May 24, 2008, 02:05:29 am »
I need to find main bearing studs wich would go with main bearing girdle..
