Author Topic: noob questions  (Read 2601 times)
February 24, 2008, 04:22:26 pm
mufflerbearing
  • 61
noob questions
« on: February 24, 2008, 04:22:26 pm »
i have a na to td project in the works using an old bae kit. after scouring the forums it seems that every thread regarding the use of a turbocharger has at least one post about making sure an egt gauge is used and that aircraft spruce makes the best probes.
im pretty set on using this gauge:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO%2D310151&N=700+4294925228+400267+4294822101+4294905482+115&autoview=sku
unless someone can suggest something different that has the same look.
and which probe do i use with it?
thanks!
-j
Reply #1February 24, 2008, 04:47:08 pm
blkboostedtruck
  • 1535
noob questions
« Reply #1 on: February 24, 2008, 04:47:08 pm »
also mufflerbearing go back to your profile and add your locaton!
I own a B.A.E. turbo and one of my friends here in milwaukee has a kit also!
it's nice to know where B.A.E.'s live!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2February 24, 2008, 05:38:03 pm
mufflerbearing
  • 61
noob questions
« Reply #2 on: February 24, 2008, 05:38:03 pm »
added my location, but i was unable to find anything with that part number on aircraft spruce. did you mean 10-01478?
still searching.
thanks
-j
Reply #3February 24, 2008, 07:19:58 pm
flapjack
  • 283
noob questions
« Reply #3 on: February 24, 2008, 07:19:58 pm »
signature
Reply #4February 25, 2008, 10:11:59 am
mufflerbearing
  • 61
noob questions
« Reply #4 on: February 25, 2008, 10:11:59 am »
i cant find any specs on the length of the cable, will i need an extension?
thanks again for all the help! hopefully ill get this thing running before im old and gray.
-j
