can a k14 compressor housing be rotated
Topic: can a k14 compressor housing be rotated (Read 2106 times)
February 24, 2008, 02:03:01 pm
GTD.
February 24, 2008, 02:03:01 pm »
can a k14 compressor housing be rotated so the outlet points down instead of up?
This might make plumbing my front mounted intercooler off a Volvo easier if the pipework could run round the timing belt covers instead of over it.
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
February 25, 2008, 07:30:05 am
flapjack
February 25, 2008, 07:30:05 am »
are you using an internal wastegate? the bracket holding the actuator uses the same bolts as the scroll, so when you spin it, it may not line up.
signature
February 25, 2008, 12:12:53 pm
February 25, 2008, 12:12:53 pm »
Are all K14s the same?
February 25, 2008, 01:10:37 pm
February 25, 2008, 01:10:37 pm »
I've never seen one that looked different construction wise if that's what you mean. Someone said the 1.9 was bigger than the 1.6 version though. Probably a different AR
February 25, 2008, 05:12:49 pm
February 25, 2008, 05:12:49 pm »
There is also the watercooled one too right?
