Author Topic: ARP part no's for ALH  (Read 13616 times)
February 12, 2008, 10:26:05 am
Helliouse
  • 164
« on: February 12, 2008, 10:26:05 am »
Does any one have these?
Head
Mains
Rods
The ones in the FAQ are for IDI.
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #1February 13, 2008, 07:23:32 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
« Reply #1 on: February 13, 2008, 07:23:32 pm »
I tried the studs for the alh and went back to stock because I was lifting heads with 25psi levels.... The stock ones worked great up to that point. How much are you planning on pushing?
Reply #2February 14, 2008, 07:33:48 am
« Reply #2 on: February 14, 2008, 07:33:48 am »
Mostly due to incorrect installation.  IIRC the ARP head studs used for TDI's are actually a Cosworth naturally aspirated ford engine, and the instructions for torquing them down are also for the Cosworth.  While I'm not sure what has been determined to be the "right" way, I've heard of people giving them an extra 90* after final torque, also people re-torquing them after x-number of miles.  Anybody know what Raceware's torque specifications are?
Reply #3February 14, 2008, 10:28:48 am
Helliouse
  • 164
« Reply #3 on: February 14, 2008, 10:28:48 am »
How far am I going to push it...well not really sure right now. but 270whp is something i want to see, if the ol' tranny can hold it... LOL
I can't see anything over 40lb, as turbo's start getting $$ for that kind of presure.
Reply #4February 14, 2008, 10:48:17 am
« Reply #4 on: February 14, 2008, 10:48:17 am »
Quote from: "lord_verminaard"
Guess I really never thought of that. The studs should be more than strong enough for extra tightening. Anyone with stretch bolts ever found what the final torque is for them at the end of the 90 degrees? That would probably be a good torque for the ARP's
Reply #5February 14, 2008, 11:05:00 am
syncroserge
  • 116
« Reply #5 on: February 14, 2008, 11:05:00 am »
Quote from: "jimfoo"
The ARP # is 215-4701. I put a set on my ALH and always had air in the
coolant, not much but...maybe I wasn't careful enough putting them in
and damaged the head gasket but..
I also think the torque spec from ARP is not enough, so...
I did a lot of reading on TDIClub, a lot of good info mixed with a BIG dose
of anecdotal old wives tales :roll:
Put a new head gasket on mine and torqued it with my eyes closed..
so I could feel things better..the ARP torque spec is no where near proper
torque for a TDI. My guess is head gasket design. The TDI gasket requires
more clamping force than a gas head gasket..seems reasonnable to assume.
The difficulty in comparing torque numbers is the thread pitch on the ARPs
is much finer than the stock bolts.
Anecdotal warning!- In the 100-110lbs range I have had no problem
so far with my engine. And that is the "consensus" also on TDIClub.
Like Brendan mentionned, knowing the torque spec of the Raceware
studs could help.
Westfalia Syncro '91 TDI se transforme lentement
mais sūrement en 16".
Jetta '97 TDI
Reply #6February 14, 2008, 12:34:34 pm
shortysclimbin
  • 138
« Reply #6 on: February 14, 2008, 12:34:34 pm »
one thing that I havent posted on tdi club because "improper installation" is sighted so much when things go wrong is that I actually followed the procedures as described and have tried the bolts out a few times. Both times I ended up redoing the head work. I also had the bolts tested at the local college and I was surprised to find that they where not as good as the oem bolts after a little bit of stress is applied. The clamping force decreases drastically after the maximum holding pressure is reach.
Some other info you might want to know...
oem bolts are 12mm 18 grade
arp studs are 11mm 10.2 grade
Let me know how they work out for you. I would be interested to know if they work at HIGH boost levels and or if people are using raceware bolts with good results at higher levels.
regards,
Kyle
Reply #7February 14, 2008, 01:58:56 pm
« Reply #7 on: February 14, 2008, 01:58:56 pm »
Quote from: "shortysclimbin"
My oem's are a little under 11mm for the main part though my ARP's are a tiny bit smaller than that. I don't see how the oem's are stronger as strength and stretch do not go hand in hand. BTW, there is no grade 18, 12.9 is the strongest metric bolt, and it wouldn't stretch much at all. If it did, it would soon fail.
Reply #8February 14, 2008, 03:46:39 pm
subsonic
  • 1836
« Reply #8 on: February 14, 2008, 03:46:39 pm »
Contact this guy:
Chris Brawn 1-805-525-1497 at ARP
Tell him what you are running and what you want to do.  Tell him about his product getting a bad rep about not holding and the blown HG's.   Pride in his product should get you the answer you are looking for.
Reply #9February 17, 2008, 09:03:11 am
hillfolk'r
  • 1532
« Reply #9 on: February 17, 2008, 09:03:11 am »
raceware told me 50 foot pounds for head studs
i said i run 40 psi,they said up them to 60 ft pounds
remember they are fine thread,so clamping load is wayy more
i tried a retorque after initial running of the engine  the next day when cooled off,and ididnt get any more from the bolts
i checked again at 1k,and nothing
but it doesnt hurt to check
the only way i blew a head gasket was running that big holset hx 35 running almost 50 psi of boost
ive got a call in to cometic to see if they can make me a custom o ringed head gasket
http://cometic.com/phuzion.aspx
Throttle cables ftw
Reply #10February 19, 2008, 08:09:17 am
Helliouse
  • 164
« Reply #10 on: February 19, 2008, 08:09:17 am »
Wow Thanks you guys for all the info!
The only problem now is what do go with... :)
Raceway or ARP
Has any one changed out the Mains and rods bolts with ARP/Raceway?
Reply #11February 19, 2008, 03:46:09 pm
Helliouse
  • 164
« Reply #11 on: February 19, 2008, 03:46:09 pm »
http://www.import-racer.com/arp/
Found this off TDI club, they list them for 1.6l-2.0l main studs
http://www.import-racer.com/sku/arp-204-5402 - Main's
http://www.import-racer.com/sku/arp-251-4701 - Head studs
They list some rod bolts, but I am not sure if they will work.
EDIT - I don't think that is the part number for the mains.
I called ARP and they have not returned my call yet, but I do hear from them I will post the part no.
Reply #12February 19, 2008, 04:14:48 pm
hillfolk'r
  • 1532
« Reply #12 on: February 19, 2008, 04:14:48 pm »
Quote from: "Helliouse"
Raceway or ARP
I did the mains also,,raceware also
reason was,on the ahu tdi,the mains are stretch also
iwanted to be able to disassemble reassemble without buying new bolts
i guess the arp head bolts have an allen hole in the top so its easier to install  if you dont remove the head,,tryin to double nut the studs and install them without lifting the head is a &**$%&*()
Throttle cables ftw
Reply #13February 19, 2008, 05:11:47 pm
syncroserge
  • 116
« Reply #13 on: February 19, 2008, 05:11:47 pm »
Quote from: "hillfolk'r"
i said i run 40 psi,they said up them to 60 ft pounds...
...the only way i blew a head gasket was running that big holset hx 35 running almost 50 psi of boost
 :shock:  :shock:  8)
any pics of all that so we can drooooooolll..
Jetta '97 TDI
Reply #14February 20, 2008, 05:03:05 pm
Helliouse
  • 164
An UPDATE
« Reply #14 on: February 20, 2008, 05:03:05 pm »
I just got off the phone with Chris Brawn, and I must say what a GREAT guy! I will give you a bit of information, as he said not say to much yet...but they are working on this for us. Which to me is very exciting, not to often have I seen a company do this...
He is to call me back on Monday with more information, but he did say that the Head studs we are using are not designed for our application.
But I got part numbers, and am very excited to hear back from him!
