Author Topic: Windshield Gasket  (Read 5682 times)
February 11, 2008, 11:17:42 pm
Baselyne
Windshield Gasket
« on: February 11, 2008, 11:17:42 pm »
Where has everyone been getting there A1 windshield gaskets from?
Im wondering if this seal is avalible and for those who bought one where did they get it from?
Im looking to buy online, possibly even your pictures or experiences in putting it in.... Is it hard??
Im told its a crazy job thats takes like 3 people to get in....ALso im told there are different kinds,,,,some are 1pc and some glue in....
I gotta stop the puddle behind the dash dripping in from the winsdhield seal
thanks in advance any in-put welcome
Reply #1February 12, 2008, 01:13:02 am
Windshield Gasket
« Reply #1 on: February 12, 2008, 01:13:02 am »
i would almost use some caulking or something... much cheaper & faster  :)
Reply #2February 12, 2008, 04:48:15 am
Windshield Gasket
« Reply #2 on: February 12, 2008, 04:48:15 am »
What style gasket do you have now. Glue in or seal? There are 2 different sized windshields depending on what style you have. Glue in I would leave to the pros, seal style can be done with 2 people
Reply #3February 12, 2008, 04:59:30 am
Baselyne
How to tell which is which?
« Reply #3 on: February 12, 2008, 04:59:30 am »
I wondering since i plan on ordering this gasket....
How would one tell if they have glue in or the other one?
which model year and whatnot....?
Reply #4February 12, 2008, 08:26:30 am
Windshield Gasket
« Reply #4 on: February 12, 2008, 08:26:30 am »
typically the ones made in the states have the glue in. If you look at your current seal you can tell. If it's the same as the hatch (rubber around the glass) it's the seal style
Reply #5February 12, 2008, 01:21:15 pm
Quantum TD
  • 1195
Re: Windshield Gasket
« Reply #5 on: February 12, 2008, 01:21:15 pm »
What year and model is your car? 1983-up cars made in the USA (i.e. Westmoreland Rabbits and pickups) are glued in. 1988-up Cabriolets are glue-in. All others are Rubber seal style that you can do yourself with 2 people.
Basically, buy a new seal (if your car has crome or black insert trim, I suggest you opt for the trim-less style since the trimmed style always leak.
cut out the old seal, scrape any residue off the windshield, wrap the new seal around the glass, and get ready to install.
Now, what I do is get a piece of thick string (about 1/8 to 1/4 dia.) and long enough to wrap around the whole glass. I lube the string with silicone spray, and have both ends finish at the bottom center of the window. Now, set the glass in place bottom end first and have a friend hold the glass and apply firm and even pressure on the glass from the outside. Pull the string to the lower corners until the bottom of the seal is set in place. Now, slowly pull one end of the string from the inside and have your friend push on the outside of the glass in  the area where you are pulling the string. He/she should keep even pressure at that point, while holding the rest of the glass in place. As you pull the string, you should see the lower flap of the seal come around the windshield frame, as it leaves an even 3/4-to-1 inch wide seal on the inside of the frame. Keep pulling the string until you have this reveal all along the inside of the frame, and the ouside of the glass is flush with the surface of the car.
Once the string is removed, make sure that the seal is even all along the inside perimeter and there are no folds or kinks. You may also have to go along the outside perimeter and push the glass to help center it in the frame, or push on the seal to remove high-spots.
That's it.
Seals can be bought new for about $30-40. Febi makes them, as do other companies.
Reply #6February 12, 2008, 01:44:35 pm
Windshield Gasket
« Reply #6 on: February 12, 2008, 01:44:35 pm »
I usually wrap the sting around twice and I've also heard to use urethane between the seal and glass to help prevent leaks. I used a used seal and used silicon and it worked great
Reply #7February 14, 2008, 01:17:05 pm
VWralley
  • 50
Windshield Gasket
« Reply #7 on: February 14, 2008, 01:17:05 pm »
if you have the rope-in type, i have two brand new OEM seals that id sell for a good price.
i tried to install two in my 77 and broke em both, so i just pay to have it installed now  :lol:
77 rabbit 16v MSnS
85 Audi 4KQ
81 Rabbit 4dr diesel
Traksclothing.com Demonrally.com
