Author Topic: Building my mk2 1.6TD  (Read 13182 times)
February 09, 2008, 09:03:32 pm
« on: February 09, 2008, 09:03:32 pm »
http://www.dubnetworks.net/showthread.php?p=18101#post18101
For anyone that's interested.
Made some progress today. The new engine is all but assembled I just need to clean up the intake manifold, block off the factory pop off valve and get the P/S and A/C pump mounted up.
If anyone has some suggestions please feel free to post up as I go.
Reply #1February 18, 2008, 06:36:45 am
Baselyne
« Reply #1 on: February 18, 2008, 06:36:45 am »
Killer wheels man, Im totaly tuned into this build! Nice work btw
Keep her in motion
Reply #2February 18, 2008, 06:57:39 am
spencebm
  • 686
« Reply #2 on: February 18, 2008, 06:57:39 am »
everything looks very clean! good luck!
Ben Spencer
Reply #3February 18, 2008, 03:44:11 pm
blkboostedtruck
  • 1535
« Reply #3 on: February 18, 2008, 03:44:11 pm »
Dang Dan! those rims are bad ass! i like those! hey do you need a upper radiator hose for your MK2? i have one thats new was sent as a wrong part to me from parts place! cost me like 44bucks and i don't have a MK2 and i don't have the recipt anymore to return it!
let me know?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4February 18, 2008, 06:59:23 pm
« Reply #4 on: February 18, 2008, 06:59:23 pm »
Quote from: "blkboostedtruck"
let me know?
thanks Duane
Crap Duane I JUST bought all my hoses from myke_w!!!!!!
I may take it anyway ;)
Thanks for the comments guys, had allot going on over the last few weeks that has really slowed me down. Lost a cousin then had to run to Seattle and now I've been sick for 7 days tomorrow..
I spent some time out there yesterday but I was working on blkboostedtruck's pump ;)
Reply #5February 24, 2008, 09:28:02 pm
« Reply #5 on: February 24, 2008, 09:28:02 pm »
Reply #6February 24, 2008, 10:22:32 pm
Op-Ivy
  • 513
« Reply #6 on: February 24, 2008, 10:22:32 pm »
Nice! What size are the wheels?
Reply #7February 25, 2008, 03:36:59 am
Baselyne
« Reply #7 on: February 25, 2008, 03:36:59 am »
Killer shot there... I love how the rims look in front of those shiny re-built caliper....
It all looks good togethor, Im also wondering what size the wheels are!
Your doing well, really well! Motor looks so nice an clean...wowo
 keep going!
Will you sell those OEM vw wheels? What are they from?
Lastly Im really wondering which suspension you put in vs. rim sie because Im sure I have the same suspension but mines not sitting like that at all...
What's your secret?
Reply #8February 25, 2008, 07:15:10 am
« Reply #8 on: February 25, 2008, 07:15:10 am »
Quote from: "Baselyne"
 keep going!
What's your secret?
The Wheels are 16" Keskin's. 7.5 in the front and 9" in the rear.
I suspect I can sell the OEM wheel as they wont clear the brakes now.
They are off my 96 Jetta, tires are dang near new as well.
The suspension consists of KYB GR2 struts and Neuspeed Soft Sport Springs, specs say they only lower it .5" so I cut a coil off. not looking for a ground scraper but I do want it lower than a .5" drop.
Reply #9March 01, 2008, 07:13:04 pm
« Reply #9 on: March 01, 2008, 07:13:04 pm »
This baby is up and running.
I have a few issues to address though.
The delivery valve I installed seem to be to big, I'm getting a really lopey idle.
I dont have any power going to my cooling fan relay.
Then the worst part, my clutch is messed up.
Feels like its worn out (new clutch disk) I have no peddle movement to speak of. I have about 2" of peddle movement off the floor and as a result I cant get it in 1st when it's running. It doesnt slip at all under heavy accell though.
Just feels like the push rod is to short and isnt sticking out the input shaft far enough, I wonder if I used the wrong plate that pushes on the pressure plate????
Anyway, it's about done.
Reply #10March 01, 2008, 07:18:55 pm
blkboostedtruck
  • 1535
« Reply #10 on: March 01, 2008, 07:18:55 pm »
you talking about that 10mm i sent you?
Duane
'66 variant 1500S
Reply #11March 01, 2008, 07:26:33 pm
« Reply #11 on: March 01, 2008, 07:26:33 pm »
Duane
No, under where the injection lines attach to the IP is where I'm referring to.
There are valves under there called "Delivery Valves". The ones I uses where from a 2.4ltr Toyota pump and the groves where much larger so I figured they would allow the fuel from the 10mm head through easier.
Well it does but a tad to much.
Ever seen a 1.6 smoke while idling?
I'll see if I can get a vid of it tomorrow. Lopey idle and black puffs of smoke with each lope.
Reply #12March 01, 2008, 07:33:45 pm
blkboostedtruck
  • 1535
« Reply #12 on: March 01, 2008, 07:33:45 pm »
ahh ok !a vid. be great like to see that!
Duane
'66 variant 1500S
Reply #13March 02, 2008, 09:59:14 pm
« Reply #13 on: March 02, 2008, 09:59:14 pm »
http://www.youtube.com/watch?v=cUhz7aWZ35E
Here is a short vid.
The engine was cold so it wasn't smoking like it does when warm.
It will blow black smoke rings when it's warm.
Reply #14March 05, 2008, 03:22:42 pm
« Reply #14 on: March 05, 2008, 03:22:42 pm »
Getting closer to done.
