1.6TD oil return
Topic: 1.6TD oil return (Read 2378 times)
February 08, 2008, 05:42:21 pm
boxer246
1.6TD oil return
February 08, 2008, 05:42:21 pm »
Building a 1.6TD for my Caddy....and have no drain line for turbo, so I was planning on using 1/2" nipple coming off the turbo and a 1/2" 90 deg nipple into the pan. Is the 1/2" nipple big enough? The inner diameter of it is smaller than the actual outlet hole on the turbo. I'm still trying to find a way to thread the 3/8 NPT into the oil pan. I was going to weld on a bung, but cant find one in steel thats 3/8"...only brass.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
February 09, 2008, 09:00:08 pm
mtnsammy
1.6TD oil return
February 09, 2008, 09:00:08 pm »
Here in California we have shops like "The Hose Man" Any hydraulic shop can set you up with a quality hose braided or not that can be put on and taken off easily. My hose is only 1/2 ID but the drain tube from the turbo is 3/8. I am sure 1/2 is plenty. Post a picture when you are done. I am looking for a better way since I have a Chevy Alt at 125 amps getting in the way of my drain.
February 10, 2008, 04:10:45 am
dillenger1
1.6TD oil return
February 10, 2008, 04:10:45 am »
I went to tractor supply and bought a length of 1/2'' hyd. hose.I then welded a "black pipe"fitting(1/2")to the oil pan.I will then make a plate for the return and sodder the brass nipple to it.I measured the oil drain for the tdi and its only 1/2" so i called it good.
The hardest part was getting the black pipe sealed to the pan and water tight with the tig.
1.6td in toyota pickup
10mm head ,t3 intercooled.
February 10, 2008, 07:21:40 am
boxer246
drain
February 10, 2008, 07:21:40 am »
yeah I was thinking about welding a 1/2" pipe onto the pan, then reducing down to 3/8" so I can screw my 90 deg fitting on to it. I already made a aluminum plate to bolt onto the bottom of the turbo, I will tap it for 3/8 NPT for my brass 1/2" nipple.
Ash
1.6TD oil return
