Author Topic: How to fix door handles on Mk2?  (Read 6468 times)
February 08, 2008, 01:03:27 pm
914turboford
« on: February 08, 2008, 01:03:27 pm »
Is there some sort of fix for the door handles on a Mk2? or Mk1, for that matter. Everyone seems to accept the fact that the doors are difficult to open from the outside. Can you bend the linkage or something?
Brian
Reply #1February 08, 2008, 01:04:45 pm
rallydiesel
  • 1880
« Reply #1 on: February 08, 2008, 01:04:45 pm »
Moving the striker pin a bit usually makes a big difference. Spray some WD40 into the lever to loosen it up as well.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2February 08, 2008, 02:32:21 pm
« Reply #2 on: February 08, 2008, 02:32:21 pm »
i've broken one once from extreme cold (20 year old car)... it was so brittle  :lol: needless to say i spray in some rust check every year or so... it makes the difference
Reply #3February 11, 2008, 07:18:49 am
Zulfiqar
  • 254
« Reply #3 on: February 11, 2008, 07:18:49 am »
I put some heatshrink tubing on the finger that presses the lock mechanism tongue, I can now open it with one finger pull
and liberally lube up the handle crank mechanism with ATF
Diesel IS the future
Reply #4February 11, 2008, 11:12:06 am
« Reply #4 on: February 11, 2008, 11:12:06 am »
I've found that if the handle is sticking shut you can loosen the screw in the side of the door a bit and that usually helps
Reply #5February 11, 2008, 11:45:30 am
« Reply #5 on: February 11, 2008, 11:45:30 am »
Replace them with mk3 style handles and keep them lubed up as mentioned above.
Reply #6February 11, 2008, 12:38:51 pm
914turboford
« Reply #6 on: February 11, 2008, 12:38:51 pm »
Thank you for the advice.
Brian
Reply #7February 12, 2008, 07:34:52 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #7 on: February 12, 2008, 07:34:52 am »
Make certain you lube the locking/latching mechanism, the grit in latch causes the extra stress to be placed on the door handle mechanism.
