Author Topic: cheap power  (Read 3129 times)
February 06, 2008, 10:31:15 pm
shegel
  • 312
cheap power
« on: February 06, 2008, 10:31:15 pm »
a friend told me that truckers will vice grip the return line going back to the tanks. i was thinking of doing this on my car but im a little concerned about the extra pressure that the pump will experience. do i have a good reason to be concerned or can i vice grip away.....(if i end up doing it. i will put a solenoid in line so i can just hit a button)
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1February 07, 2008, 02:13:17 am
Op-Ivy
  • 513
cheap power
« Reply #1 on: February 07, 2008, 02:13:17 am »
Don't. That sounds terrible. If you are considering increasing the IP's internal pressure look into doing it with the pressure control valve. I'm learning about it right now too.
http://www.vwdieselparts.com/forum/viewtopic.php?t=5936
Matt
Reply #2February 07, 2008, 05:09:11 am
cheap power
« Reply #2 on: February 07, 2008, 05:09:11 am »
man those truckers...  :lol:
i can only imagine what would happen... your return lines would probably burst off and then the engine would stall due to air in the lines.  :roll:
do like op-ivy says.  i've tried tapping on my pressure control valve and the butt dyno says that i've a little more power on the top end now  :D be careful when you do it... small taps because if you go too much you need to take it off (be VERY clean when doing so) and then tap on it from underneath.  and without measuring the actual pressure, you could do more harm than good.
good luck!
Reply #3February 07, 2008, 06:48:01 am
zaprzal
  • 160
    • turbodiesel.pl
cheap power
« Reply #3 on: February 07, 2008, 06:48:01 am »
Quote from: "jtanguay"
do you have any ideas how we can measure internal pump pressure and/or timing advance?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #4February 07, 2008, 06:52:31 am
cheap power
« Reply #4 on: February 07, 2008, 06:52:31 am »
Do a search. There is a thread on it along with pics of Libbybapa's adapter.
Reply #5February 07, 2008, 08:35:20 am
cheap power
« Reply #5 on: February 07, 2008, 08:35:20 am »
I highly doubt a trucker is going to do this to their million dollar truck :roll:
Reply #6February 07, 2008, 08:38:34 am
cheap power
« Reply #6 on: February 07, 2008, 08:38:34 am »
Plus I'd think if the pump is set up right, it would only hurt things power or economy wise. It would basically just be advancing the timing due to higher internal pressure wouldn't it?
Reply #7February 07, 2008, 09:37:03 am
myke_w
  • 1099
cheap power
« Reply #7 on: February 07, 2008, 09:37:03 am »
FYI, there is restriction built into the banjo bolt that fastens the return line to the tank
Reply #8February 07, 2008, 10:23:29 am
Op-Ivy
  • 513
cheap power
« Reply #8 on: February 07, 2008, 10:23:29 am »
Check the link I posted Zap. Everything you need to know is in there, including examples of adapters that people have made.
Reply #9February 07, 2008, 10:38:48 am
shegel
  • 312
cheap power
« Reply #9 on: February 07, 2008, 10:38:48 am »
this is why i come in here and ask before i do stuff to my car
Reply #10February 07, 2008, 11:25:21 am
cheap power
« Reply #10 on: February 07, 2008, 11:25:21 am »
Quote from: "shegel"
ALWAYS so much better than doing it the other way around!
