Author Topic: Stretch head bolt question.  (Read 15208 times)
Reply #15February 07, 2008, 03:56:06 pm
  • 3255
    • My collection of HOWTOs
« Reply #15 on: February 07, 2008, 03:56:06 pm »
When in doubt with the vagarities of the Bentley I usually assume their instructions are to be taken literally, for better or worse.
Sometimes they say "use anti seize and tighten to blah" so I assume they have taken lubrication into the mix.
Sometimes they say "apply a light coat of oil".
In the case of the headbolts, for the MK2 at least, they say nothing... so I assume the torque value is for dry.
Of course, when you ASS U ME something...
Reply #16February 08, 2008, 12:49:31 am
Quantum TD
  • 1195
« Reply #16 on: February 08, 2008, 12:49:31 am »
Quote from: "Vincent Waldon"
Hmmm. Theres the rub. I wish those twats at Bentley were a bit more explicit, especially on something this critical. Crap, I thought Haynes sucked a wad...
Reply #17February 08, 2008, 06:22:07 am
« Reply #17 on: February 08, 2008, 06:22:07 am »
My Haynes states all it's torque values are for dry threads. The funny thing is it doesn't have torque specs for the head bolts that I've ever found.
Reply #18February 08, 2008, 07:26:38 am
saurkraut
  • 904
« Reply #18 on: February 08, 2008, 07:26:38 am »
Here's what I believe is the main reason VW went to strech bolts.  Multispindle screw insetion/torqueing machines.  Brand new, squeeky clean holes and screws.  Works great, lasts along time.  The only time a human touches these screws is if one falls out of the hopper.
And that may explain why the manuals are vague about the 'by hand' procedure.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #19February 08, 2008, 01:07:46 pm
Baselyne
wet or dry
« Reply #19 on: February 08, 2008, 01:07:46 pm »
I guess it can't be so simple... What was everyone else doing? Wet intall or dry then?
Reply #20February 08, 2008, 08:31:31 pm
Vanagoner
  • 219
« Reply #20 on: February 08, 2008, 08:31:31 pm »
Saurkraut- you've solved it!  all we need to do is each of us get one of them multispindle factory tools and more stretch bolts!  We'd git-er-done in a jiffy!
Sage
'82  Vanagon Westy, the mighty N/A
Reply #21February 08, 2008, 09:48:53 pm
Slave2School
  • 531
« Reply #21 on: February 08, 2008, 09:48:53 pm »
Don't forget the VW lube!
Waiting for a bigger better diesel to come along.
2002 ford focme wagon
Reply #22February 10, 2008, 02:24:51 pm
Baselyne
« Reply #22 on: February 10, 2008, 02:24:51 pm »
so yes lube or none? on my arp's or racewear when I make my mind up which ones im getting?
Reply #23February 10, 2008, 08:14:11 pm
« Reply #23 on: February 10, 2008, 08:14:11 pm »
Lube on ARP, not sure what Raceware specs. ARP has specs for either their moly lube or 10w30, whichever you use.
Reply #24February 11, 2008, 01:08:45 am
Baselyne
« Reply #24 on: February 11, 2008, 01:08:45 am »
does anyone know what ARP's 11mm bolts cost?
Can't you get them at multipul places in the states?
Reply #25February 11, 2008, 09:33:29 pm
Quantum TD
  • 1195
« Reply #25 on: February 11, 2008, 09:33:29 pm »
Update. I just got a new set of head bolts (also FEBI) from another supplier. They came as a set (in a plastic bag) and are all coated in oil. What do I do now? Wash it off and go dry? Use the oil on there? Wash it off and use another type of oil?
F**king Bentley a#*holes.
Reply #26February 11, 2008, 10:34:43 pm
Baselyne
sometimes I couldnt agree more!
« Reply #26 on: February 11, 2008, 10:34:43 pm »
2nd that!
Reply #27February 12, 2008, 04:46:41 am
« Reply #27 on: February 12, 2008, 04:46:41 am »
I use them as is. Whenever I get head bolts, they always have had that light oil you speak of
