Author Topic: Pop tester additional uses  (Read 2571 times)
February 06, 2008, 03:06:17 pm
subsonic
  • 1836
« on: February 06, 2008, 03:06:17 pm »
Can the pop tester that we use for injectors also be used to check the function of the oil squirters if removed from a TD block?
Reply #1February 06, 2008, 03:18:03 pm
« Reply #1 on: February 06, 2008, 03:18:03 pm »
Personally I wouldn't' with mine:
- the 30 psi operating pressure would hardly show up on the gauge
- it would contaminate the system with engine oil
Reply #2February 06, 2008, 07:08:15 pm
subsonic
  • 1836
« Reply #2 on: February 06, 2008, 07:08:15 pm »
What pressure do they squirt at?
Reply #3February 06, 2008, 09:09:50 pm
« Reply #3 on: February 06, 2008, 09:09:50 pm »
Quote from: "libbybapa"
I've done it.
Livin' on the edge, eh ??!!!!
Reply #4February 06, 2008, 10:18:21 pm
bigblockchev
  • 271
pop tester useage
« Reply #4 on: February 06, 2008, 10:18:21 pm »
I'm thinking of trying to break loose a seized engine with one. Seems less crude and more controllable than  hammering  a block of wood on top of the piston. Comments anyone. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #5February 07, 2008, 05:12:42 am
« Reply #5 on: February 07, 2008, 05:12:42 am »
they should open at around 1.2 bar iirc
Reply #6February 08, 2008, 04:33:56 am
moTthediesel
  • 194
Re: pop tester useage
« Reply #6 on: February 08, 2008, 04:33:56 am »
Quote from: "bigblockchev"
You could, but I've always used a grease gun for that. Just weld a 1/8" pipe coupling to a glow plug body with the core removed and install a common zerk fitting. Fill the cylinder (make sure the valves are closed and it's not at BDC or TDC) with heavy oil and the start pumping in grease.
It will move  :wink:
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
