Author Topic: 1.5 head on 1.6 block  (Read 2499 times)
February 05, 2008, 09:51:31 pm
Baselyne
« on: February 05, 2008, 09:51:31 pm »
In reverse of this thread http://vwdiesel.net/phpBB/viewtopic.php?t=12505
heads mechanical
blocks hydro
what would you say is the chance of getting this to work?
I figure using some parts from 1.5 and some from 1.6 to make the pump  work?
wouldnt the oil squirters still be cooling the piston rings?
which head gasket i wonder? I suppose the head would need drilled to fit 12 mm bolts.?
Reply #1February 06, 2008, 02:01:06 pm
Baselyne
« Reply #1 on: February 06, 2008, 02:01:06 pm »
does this not work or?  Imagine you were a newbee and just wanted to know what was avalible as far as options go
Reply #2February 06, 2008, 05:47:41 pm
saurkraut
  • 904
« Reply #2 on: February 06, 2008, 05:47:41 pm »
The 1.5 and 1.6 blocks have the same bore. The difference is in stroke.  The 1.5 has a shorter stroke.  I believe the 1.5 also had a half a point higher compression ratio.
Therefore, the 1.5 head has smaller swirl chambers.  If you put it on a 1.6 block, you'll have even higher compression.  Probably a really bad idea if you want to run more than stock boost.
How about a 1.6 head on a 1.6 block, and a 1.5 head on a 1.5 block.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3February 07, 2008, 05:39:48 am
saurkraut
  • 904
« Reply #3 on: February 07, 2008, 05:39:48 am »
There's some on-line info at various sites that has bore, stroke and CR for the VW IDI engines.  I have one in a word document that I copied off the internets.  I'm not smart enough to successfully cut and paste it here.
A long time ago, I worked the bore, stroke, and CR stuff backwards and came up with these BALL PARK numbers for the swirl chamber volume differences.  I have all these heads in my garage, and a burette, and sometime I will actually measure them with an injector, heat shield, and glow plug in the hole  They are GENERALLY right and good enough my plans, which inclued a frakinmotor this spring.  This will yield an extra 1.6 head, and guess where I was thinking of putting that head.
1.5 Swirl chamber volume 11.457 cc
1.6 Swirl chamber volume 12.794 cc
1.9 Swirl chamber volume 16.376 cc
1.6 with 1.9 head CR: 19.357
1.5 with 1.6 head CR: 21.371
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
