Author Topic: Which fuel lines to use  (Read 2360 times)
April 02, 2005, 12:42:42 am
neich
  • 28
« on: April 02, 2005, 12:42:42 am »
Hi all,
I have a T3 syncro with an AAZ swapped that still uses the fuel pump from the old 1.6TD (JX). I am going to rebuilt the pump and I also want to change the fuel lines. The problem is that I don't know which ones shoul I buy. The ones for the AAZ or the ones for the JX ?
My guess is that the body of the 1.6TD fuel pump is the same that the 1.9TD, so I should buy the AAZ ones. Any hint ?
Thanks
Nacho
Reply #1April 02, 2005, 06:01:50 am
QuickTD
  • 1156
« Reply #1 on: April 02, 2005, 06:01:50 am »
You will need to use the AAZ lines. They fit the tall two-spring injectors properly. You don't really want to buy them though, last I heard they were over $100 each at the dealer...
