Author Topic: oil filter relocation kit. Where to buy?  (Read 4337 times)
February 03, 2008, 06:40:17 pm
haybayian
  • 155
« on: February 03, 2008, 06:40:17 pm »
Hi diesel friends,
I have spent part of this evening trying to find a source for an Oil filter relocation kit for my 1993 Jetta TD engine with no luck. Lots of parts for gassers, or north american diesels, but nothing for me.
Do you have any suggestions?
Thanks.
Haybayian
Keep it simple if you can.
Reply #1February 03, 2008, 07:27:58 pm
« Reply #1 on: February 03, 2008, 07:27:58 pm »
I just used a kit for a Ford.
Reply #2February 04, 2008, 11:45:16 pm
Turbinepowered
  • 1206
« Reply #2 on: February 04, 2008, 11:45:16 pm »
Reply #3February 05, 2008, 05:15:36 am
haybayian
  • 155
« Reply #3 on: February 05, 2008, 05:15:36 am »
Quote from: "Turbinepowered"
Would something like this work?
Or even be any good?
I talked to JC Whitney yesterday and their desk person told me that these kits should not be used with diesel. Perma-Cool 106 95 (tel: 1 909 390 1550) on the other hand should do.
Haybayian
Reply #4February 05, 2008, 06:15:04 am
« Reply #4 on: February 05, 2008, 06:15:04 am »
The PH8A filter is a Ford filter, same threads as a VW filter BTW. Perma-Cool 10695 looks exactly like what I have on. I also had my local auto parts store get it for me. You should be able to get one almost anywhere though you may have to ask them.
Reply #5February 05, 2008, 09:04:03 am
flash319
  • 163
« Reply #5 on: February 05, 2008, 09:04:03 am »
SUMMIT has there store brand and Perma cool kits.  I am going to get one of the store brand ones for my AAZ.
Reply #6February 05, 2008, 09:11:25 am
« Reply #6 on: February 05, 2008, 09:11:25 am »
i wonder why they say not to use the filter relocation units on diesels... what gives???  higher oil pressures or something???
Reply #7February 05, 2008, 09:27:18 am
« Reply #7 on: February 05, 2008, 09:27:18 am »
Only problem I had was one of my hoses I had made up with hydraulic ends started leaking at the swivel joint. Shouldn't be a Diesel problem as the fittings should hold 3000+psi
Reply #8February 05, 2008, 10:14:32 am
haybayian
  • 155
« Reply #8 on: February 05, 2008, 10:14:32 am »
Quote from: "jtanguay"
I was told by JC Whitney desk guy that the aluminum alloy is what the manufacturer does not trust. Personally I don't have a clue.
Haybayian.
Reply #9February 05, 2008, 10:32:21 am
« Reply #9 on: February 05, 2008, 10:32:21 am »
The only ones I've EVER seen are aluminum. I've had mine for a few years.
Reply #10February 05, 2008, 04:27:01 pm
Turbinepowered
  • 1206
« Reply #10 on: February 05, 2008, 04:27:01 pm »
I only live a couple hour's drive from SUMMIT... :D
Reply #11February 05, 2008, 05:12:45 pm
« Reply #11 on: February 05, 2008, 05:12:45 pm »
isn't the oil cooler aluminum???  :roll:   :lol:
Reply #12February 06, 2008, 12:25:11 pm
haybayian
  • 155
« Reply #12 on: February 06, 2008, 12:25:11 pm »
 :D  OK guys....I have  indeed myself  run various aluminum items with my Volvo   and my Detroit diesel engines  for years and I am not aware of a diesel aluminum incompatibility. So ....!!!!I may have been given a bit of BS from the JC Whitney salesman.  It happens.
However...This being said, I have read  here and there  on the Net that some of these filter relocation kits are not diesel compatible. The following Summit link is one
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TRD%2D1122&N=700+400158+301916+115&autoview=sku
As for the why? go figure.
Haybayian
Reply #13February 06, 2008, 12:57:30 pm
flash319
  • 163
« Reply #13 on: February 06, 2008, 12:57:30 pm »
Could it be that they do not want you to use it for diesel fuel?  I could see why because the filters are not made for diesel.  A lot of diesels have the same type of filter assembly but use diesel fuel filters. They don't want you running diesel fuel through it not engine oil.
