Author Topic: TDI vs IDI head external signs  (Read 2906 times)
February 03, 2008, 04:38:26 am
haybayian
  • 155
« on: February 03, 2008, 04:38:26 am »
Could someone tell me what the external signs of a TDI head are versus the IDI's. I am working on a reman 1.9  TD  and I would like to make sure that the shop did not sell me an IDI engine with a TDI head. I am aware that this may be a profoundly stupid question, but bear with me I am new to these engines.
Thanks.
Haybayian
Keep it simple if you can.
Reply #1February 03, 2008, 04:59:31 am
dillenger1
  • 777
« Reply #1 on: February 03, 2008, 04:59:31 am »
The valve cover will have recesses for the cover bolts.The side profile looking down is wavy on a tdi.Also the oil cap looks like a gas cap on the tdi.HAHA i dont know if this helps i dont have any cating no.s
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2February 03, 2008, 06:25:41 am
« Reply #2 on: February 03, 2008, 06:25:41 am »
It doesn't have threaded holes for the injectors.  Your injector lines won't fit on the injectors.
Reply #3February 03, 2008, 06:28:02 am
haybayian
  • 155
« Reply #3 on: February 03, 2008, 06:28:02 am »
Quote from: "dillenger1"
My hope is that someone here will be familiar with the actual alloy castings; they are bound to bear different numbers and perhaps ports size and locations.
Thanks for trying.
Reply #4February 03, 2008, 06:32:34 am
« Reply #4 on: February 03, 2008, 06:32:34 am »
Ports are the same. Just look at my IDI to TDI thread and you will see what a TDI head looks like(of the only kind that would fit on). The upper water hose has the bolts vertically instead of diagonally.
Reply #5February 03, 2008, 06:38:34 am
« Reply #5 on: February 03, 2008, 06:38:34 am »
Well crap, I guess I have to fix the links to the pics. Guess it's my host's problems.
Reply #6February 03, 2008, 07:04:17 am
« Reply #6 on: February 03, 2008, 07:04:17 am »
Ok, pics are back. Here is what a TDI head would look like.
If yours doesn't look like that, then it isn't one.
Reply #7February 03, 2008, 07:10:02 am
haybayian
  • 155
« Reply #7 on: February 03, 2008, 07:10:02 am »
Quote from: jimfoo
Thanks very much Jim,
Yes I can see the shape of the casting (Wavy line). Mine is indeed an IDI.
