Author Topic: POR engine enamel ?  (Read 7634 times)
January 31, 2008, 04:45:00 am
stewardc
POR engine enamel ?
« on: January 31, 2008, 04:45:00 am »
Has anyone ever used this to paint a block? How was it?
http://www.por15.com/products.asp?dept=7
Reply #1January 31, 2008, 05:03:34 am
Mark(The Miser)UK
  • 1557
POR engine enamel ?
« Reply #1 on: January 31, 2008, 05:03:34 am »
What would be best?
Black or white?
Mark-The-Miser-UK
Reply #2January 31, 2008, 05:27:10 am
stewardc
POR engine enamel ?
« Reply #2 on: January 31, 2008, 05:27:10 am »
Quote from: "Mark(The Miser)UK"
What would be best?
Black or white?
I asked "Has anyone ever used it"?
Reply #3January 31, 2008, 07:08:59 am
POR engine enamel ?
« Reply #3 on: January 31, 2008, 07:08:59 am »
I know their regular rust preventative paint is supposed to be excellent, and that it takes weeks to wear off of your skin from what I hear. I would imagine their engine enamel should be very good quality.
Reply #4January 31, 2008, 02:57:40 pm
Mark(The Miser)UK
  • 1557
POR engine enamel ?
« Reply #4 on: January 31, 2008, 02:57:40 pm »
Quote from: "stewardc"
What would be best?
Black or white?
I assumed that the block was paintable with the enamel. Didn't VWpaint some green?
I'm asking from a physics point of view... Heat dissapation or  conservation.
Mark-The-Miser-UK
Reply #5January 31, 2008, 03:01:35 pm
stewardc
POR engine enamel ?
« Reply #5 on: January 31, 2008, 03:01:35 pm »
What would be best?
Black or white?
Aaaaah, so. Got it. Actually, I'm gonna use ford blue. Not dissipation, nor conservation, but restoration.
Reply #6February 01, 2008, 04:37:02 am
Turbinepowered
  • 1206
POR engine enamel ?
« Reply #6 on: February 01, 2008, 04:37:02 am »
What would be best?
Black or white?
From a radiation heat standpoint, black both absorbs and emits the best.
White/silver paints absorb and emit heat at much lesser rates, but I don't believe they would provide any insulating value. Not measurably, at least.
Not to mention white block paint would be a b*^&# to keep clean.
Reply #7February 01, 2008, 04:39:29 am
POR engine enamel ?
« Reply #7 on: February 01, 2008, 04:39:29 am »
i thought black is only good at absorbing light energy?  as it is the absence of all colours, it cannot reflect and thus absorbs their energy, while white being all colours, reflects the light energy.  does it really matter under the hood?
Reply #8February 01, 2008, 06:30:31 am
clbanman
  • 705
    Cambridge, Ontario
POR engine enamel ?
« Reply #8 on: February 01, 2008, 06:30:31 am »
Black does also dissipate heat better - one reason all rads get painted black if they are painted.  Flat black also does a better job than gloss.  As far as white - I have a 67 Ford that has drums on all 4 corners and they are powder coated white.  I can tell you from experience that the brake fade is horrible and they take some time to cool back down.  I would be willing to bet that if you painted your rad white you would experience some cooling issues.
Calvin
91 VW Golf 1.6NA 5spd
Reply #9February 01, 2008, 06:39:49 am
MaxHedrm
  • 114
    • blog
POR engine enamel ?
« Reply #9 on: February 01, 2008, 06:39:49 am »
Quote from: "clbanman"
I would bet that's a function of the powder coat (and the brake design) rather than the color. The powder coat is much thicker than paint and also smoothes the surface reducing your surface area for heat dissipation. That & they are drum brakes.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #10February 01, 2008, 04:22:34 pm
Mark(The Miser)UK
  • 1557
POR engine enamel ?
« Reply #10 on: February 01, 2008, 04:22:34 pm »
So would you want to retain heat in a block or loose it? :? [/color]
Mark-The-Miser-UK
Reply #11February 01, 2008, 06:02:36 pm
MaxHedrm
  • 114
    • blog
POR engine enamel ?
« Reply #11 on: February 01, 2008, 06:02:36 pm »
Good question. Retaining would be theoretically better for efficiency. I think a lot of it might depend on what sort of climate you live in. Up north, retaining might be fine, but down here in the south, getting rid of heat could be more important.
Reply #12February 01, 2008, 06:11:25 pm
clbanman
  • 705
    Cambridge, Ontario
POR engine enamel ?
« Reply #12 on: February 01, 2008, 06:11:25 pm »
OK, I did a bit of research on colour/heat transfer on the net. (for what it's worth.)
http://www.eng-tips.com/viewthread.cfm?qid=165626&page=1
The following paint has ceramic particles in it to help dissipate heat:
http://www.amazon.com/Dupli-Color-Performance-Brake-Caliper-Paint/dp/B000B6DG4Uhttp://www.partsamerica.com/ProductListSimple.aspx?Category=3268
http://www.flyelectric.ukgateway.net/black_paint.htm
I also found one site that said that only colours in the infra-red scale would actually improve heat transfer.  I guess you can prove anything on the internet.
Calvin
Reply #13February 09, 2008, 09:28:47 pm
AdAm84
POR engine enamel ?
« Reply #13 on: February 09, 2008, 09:28:47 pm »
To answer the original question. I used The POR20 which is the high heat type on my headers. I have 3500 mi. on it with no cracking. plus the flat black looks sweet  8) But, as with any painting, you have to prep it right. I bead blasted my header before i painted it.
Reply #14February 11, 2008, 02:04:57 pm
stewardc
POR engine enamel ?
« Reply #14 on: February 11, 2008, 02:04:57 pm »
Quote from: "AdAm84"
Yeah, I used that (I think it's called Black Velvet) on my whole exhaust system. It looks great.
