Author Topic: Where to buy  (Read 2814 times)
January 30, 2008, 04:27:05 pm
boosted_diesel_84
  • 216
Where to buy
« on: January 30, 2008, 04:27:05 pm »
i need a few parts yet for my build, can anyone tell me where i can get the 36mm oil pump, ARP head studs, and a freeze plug block heater?
also, which nozzles are the best to get, that will fit in a stock injector, i bought GTD, but they wouldnt fit, so which ones and where can i get them. thanks for the help, i will start a build thread as soon as block gets back from machine shop.
-Jack-
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1January 30, 2008, 07:52:10 pm
silvertdi
  • 125
Where to buy
« Reply #1 on: January 30, 2008, 07:52:10 pm »
I'd try parts place in Michigan.  I've had decent luck with them. Others have not.
Reply #2January 30, 2008, 09:55:19 pm
Where to buy
« Reply #2 on: January 30, 2008, 09:55:19 pm »
ARP studs from Summit Racing. The 12 mm ones are listed as being for a Ford Cosworth. Someone has a thread with all the different ARP numbers, but I'll let you search.
Reply #3January 30, 2008, 10:05:20 pm
subsonic
  • 1836
Where to buy
« Reply #3 on: January 30, 2008, 10:05:20 pm »
Headbolts.com had summit beat a while back.  The numbers are in the FAQ section.  Some yahoo stuck em there.
Reply #4January 30, 2008, 10:23:36 pm
MaxHedrm
  • 114
    • blog
Where to buy
« Reply #4 on: January 30, 2008, 10:23:36 pm »
You might be able to find the oil pump @ autohausaz.com ... they have one listed, but I dunno if it's hte one you're looking for.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #5January 30, 2008, 10:34:30 pm
Where to buy
« Reply #5 on: January 30, 2008, 10:34:30 pm »
myke w sells them I do believe
Reply #6January 30, 2008, 10:51:59 pm
  • 2932
Where to buy
« Reply #6 on: January 30, 2008, 10:51:59 pm »
I got mine from mikew?... I think that's his username.
 He posted on the 36mm pump thread. guarenteed 36mm.
 You might be able to get some of the other stuff from him too.
