General Information
General
Crank nose repair question
Topic: Crank nose repair question (Read 6535 times)
January 29, 2008, 05:26:17 pm
January 29, 2008, 05:26:17 pm »
I had the machine shop work on my crank so I could fit a TDI gear. The shop built up the whole crank for a tight fit, then ground the flat, but they didn't fill in the old slot. Is this going to be a problem? I imagine I could weld it up myself as the hardest part has been done, if it really needs it.
January 29, 2008, 07:05:31 pm
wyldman
Authorized Vendor
January 29, 2008, 07:05:31 pm »
I always weld them up first,then machine to fit.
I wouldn't weld it now,or you will need to remachine.
Check it for hairline cracks right around the keyway.If there are any,I'd be getting it fixed.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
January 29, 2008, 07:11:56 pm
January 29, 2008, 07:11:56 pm »
Well, I guess it would be hard for it to fail in the same manner. It is a good tight fit. Maybe I'll just JB Weld it as that can't hurt. I don't see any cracks, so I guess it isn't too bad.
January 29, 2008, 07:15:04 pm
wyldman
Authorized Vendor
January 29, 2008, 07:15:04 pm »
Did they magnaflux it ? Sometimes you cannot see the cracks.
Where did they machine the flat ? Is it 180 degrees away from the original keyway ? If so,you should be OK.I would not use any JB weld.
(416)565-7282
January 29, 2008, 07:18:44 pm
January 29, 2008, 07:18:44 pm »
Nope, it's where the original keyway was. maybe I could make my own flat on the other side.
January 29, 2008, 07:20:46 pm
wyldman
Authorized Vendor
January 29, 2008, 07:20:46 pm »
Hmmm....
I have seen a few done like that and they later cracked.
You might want to consider welding it up properly,and remaching it.
(416)565-7282
January 29, 2008, 09:39:24 pm
935racer
January 29, 2008, 09:39:24 pm »
If they machined the flat on top of the old key way it should be redone, I machine the flat 180 out from there all the time given the crank nose isn't damaged yet. If it is it gets welded up and re machined.
January 30, 2008, 10:48:44 am
January 30, 2008, 10:48:44 am »
Ok, I welded it up, about 3-4 times, and carefully ground it down, about 3-4 times, until I got it. It is now a tight press fit, I need to use the bolt to snug it up, and it has no movement. I can see where a mill or bridgeport would be very handy. I had to settle for a dremel, a very steady hand, and a very slow cutting diamond disc.
January 30, 2008, 11:23:06 am
January 30, 2008, 11:23:06 am »
Do you have any pictures?
January 30, 2008, 11:57:12 am
January 30, 2008, 11:57:12 am »
While it isn't too bad, I don't think it is nice enough for pictures as the flash seems to magnify any little imperfection, making it look far worse than it is.
January 30, 2008, 12:07:47 pm
January 30, 2008, 12:07:47 pm »
it can't be any worse then if I did it, which I'll probably end up doing one of these fine days
General Information
General
