Author Topic: Low Sulfur Diesel  (Read 5688 times)
January 26, 2008, 12:51:00 pm
Dieselumbrado
  • 19
Low Sulfur Diesel
« on: January 26, 2008, 12:51:00 pm »
Today I went by a gas station and saw a diesel pump that says Low Sulfur Diesel, 500 PPM, and was a warning saying: " This diesel is prohibit on 2007 and newer engines".
Is this the old diesel?
Reply #1January 26, 2008, 05:02:39 pm
Quantum TD
  • 1195
Low Sulfur Diesel
« Reply #1 on: January 26, 2008, 05:02:39 pm »
Yep. The new diesel is 15ppm. If you can find it, use the old stuff. Less liklihood of a leaking pump, if you haven't resealed it yet.
Reply #2January 26, 2008, 08:41:22 pm
trent77
  • 217
Low Sulfur Diesel
« Reply #2 on: January 26, 2008, 08:41:22 pm »
ya,
they have both at my local station, I have been opting for the low, not ultra low. it seems to be working well.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #3January 26, 2008, 09:05:18 pm
vegfuel
  • 125
Low Sulfur Diesel
« Reply #3 on: January 26, 2008, 09:05:18 pm »
Yeah I am pissed off with this ULSD. I don't know where to find LSD. You would think that they would supply it for all older model diesels.
Guess they never figured an old 79-81' diesel rabbit would last this long! :twisted: thanks to good ol' high sulfur diesel.
Question: what can you do if you have to use ULSD but don't want to blend biodiesel because of sub-zero temps? Any certain additive?
1986 Golf WVO converted.
Reply #4January 26, 2008, 10:00:08 pm
1985JettaTD
Low Sulfur Diesel
« Reply #4 on: January 26, 2008, 10:00:08 pm »
most truck stops still have it for the off road equiptment, at leat in canada. it is illegal to use it, but that is only if you get caught
Reply #5January 26, 2008, 10:09:03 pm
Quantum TD
  • 1195
Low Sulfur Diesel
« Reply #5 on: January 26, 2008, 10:09:03 pm »
Quote from: "vegfuel"
Age old diesel buffs swear by Stanadyne. I spoke with a diesel tech here in the US who claimed that he's pulled apart pumps on newer cars that looked like they were sandblasted inside. He recommended Stanadyne to prevent wear on the pump. I'm not sure how it does in cold weather, but as you note, if it's warm enough, go with the bio-blend.
The strange thing that I noticed on my GFs 2001 TDI, is that the new ULSD smells really bad when it's run: like burnt hair. But with the Bio-blend, it doesn't smell at all really.
Reply #6January 27, 2008, 12:21:33 am
vegfuel
  • 125
Low Sulfur Diesel
« Reply #6 on: January 27, 2008, 12:21:33 am »
Quote from: "1985JettaTD"
If only there was some secret under-the-table additive that you could use to turn red dyed diesel to a mellow-yellow!  :D
Just maybe...................... :twisted:
Reply #7January 27, 2008, 04:17:07 am
Low Sulfur Diesel
« Reply #7 on: January 27, 2008, 04:17:07 am »
some guys have added two stroke oil with some success in stopping the pump from leaking (and it adds lubrication to the pump & upper cylinder too!)
Reply #8January 27, 2008, 08:51:40 am
TedV
  • 182
Low Sulfur Diesel
« Reply #8 on: January 27, 2008, 08:51:40 am »
Power Service also has several additives available.  Most common at parts stores, truck stops, wal mart, etc are winter anti gel and summer cleaner, cetate boost that both help lube the pump.
Reply #9January 27, 2008, 09:35:19 am
eightyonerabbit
  • 51
Low Sulfur Diesel
« Reply #9 on: January 27, 2008, 09:35:19 am »
Quote from: "TedV"
that's what ive been using, and its been working for me... i know that it adds quite a bit of power and increases fuel mileage a little bit...
Reply #10January 27, 2008, 11:02:40 am
935racer
Low Sulfur Diesel
« Reply #10 on: January 27, 2008, 11:02:40 am »
Find some hippies, I am sure they could help :o
Reply #11January 28, 2008, 05:18:41 am
OM617
Low Sulfur Diesel
« Reply #11 on: January 28, 2008, 05:18:41 am »
Get used to it. By 2009 ULSD will be your only choice.
Reply #12January 28, 2008, 06:12:06 am
subsonic
  • 1836
Low Sulfur Diesel
« Reply #12 on: January 28, 2008, 06:12:06 am »
Quote from: "935racer"
Reply #13January 28, 2008, 10:17:49 am
vegfuel
  • 125
Low Sulfur Diesel
« Reply #13 on: January 28, 2008, 10:17:49 am »
Quote from: "subsonic"
"yeah doood, we can get you some LSD maaann.... what is that some kind of shroom man.." :)
Reply #14January 28, 2008, 04:20:43 pm
njj_502
  • 24
Low Sulfur Diesel
« Reply #14 on: January 28, 2008, 04:20:43 pm »
I've been using Stanadyne Performance Formula.  Have been running it since I picked up my Golf with no leaks.  That's about 20K miles and ULSD 95% of the time.  Guy I work with at Cat is a big VW nut and swears by it.
One note tho, there are two different types of this additive, one for pre 07 and one for post 07.  I was told by the fuel systems shop where I buy it that the post 07 formula contains no sulfur where as the pre 07 does.  Comes out to about $1 per fill up.
86 Golf IDI NA - Third owner as of 4/07... MINT
