Author Topic: Euro diesels for sale  (Read 4346 times)
January 26, 2008, 11:32:04 am
wyldman
  • 403
« on: January 26, 2008, 11:32:04 am »
I have two Ford Endura 1.8L Direct injected engines for sale.
These were used in prototype test vehicles for a 1 year pilot project.
They have very low miles,due to the local city routes they were used on.Both engines have less than 10,000 Km.
They are a 4 cyl,direct injected,turbocharged and intercooled engine,with everything intact.The intercoolers are not included.One has a complete wiring harness,one is partially cut up,but all the important stuff should be there.Computers are included as well,and they have had the PATS (anti-theft) disabled so they will work in any application.
These are used in some Ford cars,like the Escort,Mondeo,Transit,etc,and should be able to drop into a North American Escort,Contour,Mystique,etc as these are "world" cars,and are pretty much the same.
They would also be good for maybe a stationary generator,bobcat or small equipment conversion,etc
Again,everything is there,ready to run (except the intercooler).High pressure fuel pump,injection pump,turbo,manifolds,most wiring,etc.I even have the manifold outlets and down pipes,mufflers,all you need to do is add the pipes to fit your application.Aitbox,filter,oil coolers,mass airflow sensors,etc are also included.Even have the rads as well if needed.
Call or email for more info.The cost me some $$$ to get,but I will pass them on pretty cheap.$500 or so should get you a complete setup.
(416)565-7282
Reply #1January 26, 2008, 05:32:33 pm
blkboostedtruck
  • 1535
« Reply #1 on: January 26, 2008, 05:32:33 pm »
do you have any pics.?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2January 26, 2008, 05:37:33 pm
wyldman
  • 403
« Reply #2 on: January 26, 2008, 05:37:33 pm »
Yes,I have lots of pics,too big to post here.
I'll try and get some resized,or I can send via email.
(416)565-7282
Reply #3January 26, 2008, 05:50:04 pm
jackbombay
  • 599
« Reply #3 on: January 26, 2008, 05:50:04 pm »
Quote from: "wyldman"
  If you host them at photobucket they automatically get resized :-)
