Author Topic: Wastegate stuck open or dead - is BOV enough?  (Read 4247 times)
March 30, 2005, 12:16:42 pm
RichMason
  • 10
« on: March 30, 2005, 12:16:42 pm »
I just put a 1.6 td in my Vanagon.  The only way to get any boost is to remove the wastegate lines.  With the wastegate removed, you can sense the boost pressure to keep it low enough to avoid opening the BOV (which does work) and I drive the van gently.  DO I need to fix the wastegate or can I rely on the BOV to protect the engine?
Rich Mason
Chapel Hill, NC
2003 Gold TDI
85 Westy 1.6td
Reply #1March 30, 2005, 08:23:23 pm
Dr. Diesel
  • 1341
« Reply #1 on: March 30, 2005, 08:23:23 pm »
do you mean the turbo produces zero boost when the wastegate line is connected? What boost does it make when you disconnect?
Reply #2March 31, 2005, 05:14:20 pm
« Reply #2 on: March 31, 2005, 05:14:20 pm »
thats pretty weird... your wastegate must be pretty messed up if the only way to get boost is to remove the line.   That would mean that the wastegate spring is somehow dead, or stuck open somehow???
maybe someone changed your wastegate spring with one from a pen  :lol: time to operate!
I have some pics of the wastegate (from a service manual) if you wish me to email them I will do so.
Reply #3April 03, 2005, 11:29:45 am
racer_x
  • 123
Re: Wastegate stuck open or dead - is BOV enough?
« Reply #3 on: April 03, 2005, 11:29:45 am »
Quote from: "RichMason"
Rich Mason
Chapel Hill, NC
2003 Gold TDI
85 Westy 1.6td
I'd try to fix the wastegate. Sounds like the spring is extremely weak in it. Or something else is wrong. But it could be something really cheap/easy to fix. Either that or it's just begging for a boost control valve for the wastegate control line. :D
The pressure relief valve is a secondary safety system. I wouldn't want to rely on it as the only control of boost. It also tends to dump a lot of boost when it trips, over correcting rather than maintaining a predictable level of boost.
Reply #4April 03, 2005, 11:52:22 am
« Reply #4 on: April 03, 2005, 11:52:22 am »
definitely recommend getting a psi gauge,  and a manual boost controller.  It will take a bit of time to get the boost controller setup properly but once you get it right, you can make your wastegate open at 10 psi like normal :)
Reply #5April 03, 2005, 01:17:06 pm
vwmike
  • 1158
« Reply #5 on: April 03, 2005, 01:17:06 pm »
Quote from: "racer_x"
Rich Mason
Chapel Hill, NC
2003 Gold TDI
85 Westy 1.6td
Not to mention relying on the pop valve for boost control means you're drastically overspinning the turbo when it opens. I don't think your turbo would last long in a situation like that.
