Author Topic: IP all sealed up!!  (Read 2048 times)
January 22, 2008, 01:46:27 pm
dillenger1
  • 777
IP all sealed up!!
« on: January 22, 2008, 01:46:27 pm »
Well ,im sorry if this annoys anyone,but im so freakin excited.This is my first TD build and iam new to the forum.Ive recently finished my IP reseal/rebuild. :D With your help and a little testicular fortitude ,i managed to successfully modify my pump.The core is from a 85 na 1.6.I bought an old pump from a peuguet,and used the LDA,plunger,and head.I thought it would be alot more difficult then it was.i did the gov. spring mod"replaced with brass tubing.I also advanced the control cone,and removed the nylon stop washer.I didnt want to go to far from stock settings as i dont know what just the 10mm plunger will do.The LDA was a little hard ,but it went when the fuel screw was removed.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1February 01, 2008, 02:37:20 am
EatDog
  • 14
IP all sealed up!!
« Reply #1 on: February 01, 2008, 02:37:20 am »
did you take any pictures?
1985 Jetta 1.6TD 499,500km
Reply #2February 01, 2008, 03:02:22 am
dillenger1
  • 777
IP all sealed up!!
« Reply #2 on: February 01, 2008, 03:02:22 am »
this is the peugoet 1omm pump
this is the VW bottom with the puegoet gov. spring.I intended om using thr lda from the peugoet.
LDA mated to VW NA pump :D
Reply #3February 01, 2008, 03:05:22 am
dillenger1
  • 777
IP all sealed up!!
« Reply #3 on: February 01, 2008, 03:05:22 am »
9mm head and plunger coming off :)
TURN IT UP!! :twisted:
