Author Topic: Water pump pulley  (Read 6350 times)
January 21, 2008, 11:10:23 am
greenbert
  • 26
Water pump pulley
« on: January 21, 2008, 11:10:23 am »
My 91 ecodiesel was in the shop for timing belt and water pump. Now I got a call from my mechanic saying that  I need a new water pump pulley, but its like $215 just for the part. Is there any ware I can find 1 on the web?
1991 Volkswagen jetta ecodiesel (stock)
Reply #1January 21, 2008, 11:11:12 am
Water pump pulley
« Reply #1 on: January 21, 2008, 11:11:12 am »
What's wrong with yours?
Reply #2January 21, 2008, 11:16:17 am
Water pump pulley
« Reply #2 on: January 21, 2008, 11:16:17 am »
Reply #3January 21, 2008, 11:18:38 am
greenbert
  • 26
Water pump pulley
« Reply #3 on: January 21, 2008, 11:18:38 am »
The bearings inside the pulley are shot.
Reply #4January 21, 2008, 11:21:26 am
Baselyne
Water pump pulley
« Reply #4 on: January 21, 2008, 11:21:26 am »
you mean the water pumps shot?
Reply #5January 21, 2008, 11:22:48 am
greenbert
  • 26
Water pump pulley
« Reply #5 on: January 21, 2008, 11:22:48 am »
Nope, I was told its just the pulley
Reply #6January 21, 2008, 11:32:09 am
Turbinepowered
  • 1206
Water pump pulley
« Reply #6 on: January 21, 2008, 11:32:09 am »
That doesn't sound right... there are no bearings in the pulley itself. There's a bearing in the water pump casing, the front part that gets replaced with the pump, but nothing on the pulley... It's just a pulley.
Reply #7January 21, 2008, 11:34:40 am
Water pump pulley
« Reply #7 on: January 21, 2008, 11:34:40 am »
Sounds like he needs a waterpump, I supose there is a small chance it was bad enough that the actual pulley was rubbing on something causing it needing to be replaced as well..??
Reply #8January 21, 2008, 11:38:10 am
bert
  • 423
Water pump pulley
« Reply #8 on: January 21, 2008, 11:38:10 am »
If its like my jetta with p/s the water pump pulley has got bearings inside it,one part of it freewheels,the alternator belt does not spin the pump,the pump is driven by the p/s belt.
Bert
Reply #9January 21, 2008, 11:39:33 am
greenbert
  • 26
Water pump pulley
« Reply #9 on: January 21, 2008, 11:39:33 am »
Yes thats right, I just got off the phone with him and Its not just the solid pulley.
Reply #10January 21, 2008, 11:49:12 am
bert
  • 423
Water pump pulley
« Reply #10 on: January 21, 2008, 11:49:12 am »
:wink:
Bert
Reply #11January 21, 2008, 12:18:39 pm
Water pump pulley
« Reply #11 on: January 21, 2008, 12:18:39 pm »
perfect time to delete the PS :wink:
Reply #12January 21, 2008, 01:30:45 pm
Quantum TD
  • 1195
Water pump pulley
« Reply #12 on: January 21, 2008, 01:30:45 pm »
Gasser pulleys with the clutched pulley should work just the same. You might have to change the belt sizes though.
On the clutched pulleys, there are no beagings: just a fiber sleeve. So, you might be able to free up your old one.
Here's the part number for the correct ECOdiesel pulley:
068121028
You can get it for a lot less at www.1stvwparts.com (about $160)
Call before you order. Some of these old parts are getting hard to find.
Reply #13January 21, 2008, 02:16:43 pm
greenbert
  • 26
Water pump pulley
« Reply #13 on: January 21, 2008, 02:16:43 pm »
My mechanic is going to help out and give me free labor with the part.
Thanks for your help guys, and the link.
Tim.
Reply #14January 22, 2008, 04:53:23 am
Turbinepowered
  • 1206
Water pump pulley
« Reply #14 on: January 22, 2008, 04:53:23 am »
Stuff like this is why I love my Fox... no power steering, light weight, good handling... but I really wish they gave me a bit more room up front for belt access!
