Author Topic: Lucas IP  (Read 5680 times)
January 20, 2008, 08:23:47 am
nokivasara
  • 115
Lucas IP
« on: January 20, 2008, 08:23:47 am »
Does anyone know where to find good information about tuning Lucas IP's?
Not necessarily for more power but how to adjust fueling and idle, maybe some exploded views etc.
Iīm hearing all this crap about them so I want to learn more, either to prove them wrong or to understand whatīs so bad about them.
Caddy 1.6N/A pushing 400 000km and going strong!
Reply #1February 28, 2008, 06:13:39 am
nokivasara
  • 115
Lucas IP
« Reply #1 on: February 28, 2008, 06:13:39 am »
No one seems to be familiar with these  :?
I have a Skoda Pickup that has a Lucas IP, and would like to read a bit about them..
When it fails or starts leaking, which should happen any day now according to their reputation ( :wink: ), Iīll replace it with a Bosch. And then Iīll throw in the manifolds + turbo from a AAZ...
Reply #2February 29, 2008, 12:10:23 pm
smutts
  • 720
    ClackClackClackClackClack
Lucas IP
« Reply #2 on: February 29, 2008, 12:10:23 pm »
I might have something for the Rotodiesel. 1950's vintage. :D But I like your solution better.
Reply #3April 30, 2008, 02:06:08 pm
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
Lucas IP
« Reply #3 on: April 30, 2008, 02:06:08 pm »
Nokivasara:
Chech the swedish skodaforum on http://www.skodaklubben.se/forum/detalj.asp?TradID=12273&ForumID=4#topp
//Sierra94
<-- My M-tdi Mazda B-1800 and my other cars
Reply #4July 02, 2008, 03:29:14 am
anto
Lucas IP
« Reply #4 on: July 02, 2008, 03:29:14 am »
Alot of peugeots in Europe came with the lucas pump....my 306 dt had one till i swapped it for a bosch.
Any questions fire away, ive tuned mine so no a little about them.
Could never find much literature with regards them however.
Reply #5July 15, 2008, 02:01:58 pm
gigaz2
  • 626
Lucas IP
« Reply #5 on: July 15, 2008, 02:01:58 pm »
a picture with arrows pointing to the most important settings would be super :D
Reply #6August 03, 2008, 11:33:38 am
nokivasara
  • 115
Lucas IP
« Reply #6 on: August 03, 2008, 11:33:38 am »
Quote from: "anto"
I found a brittish forum that had a description on how to increase fueling on it. It also makes the timing more advanced at the same time.
That made a big difference in power, the performance is better than in my previous Passat Eco-diesel before I tweaked it and it got better mileage too, probably caused by the advanced timing.
Do you happen to know how to increase the max RPM's (governor mod) on a Lucas? It cuts out the fuel really abrupt, itīs like hitting the brakes....
Reply #7August 03, 2008, 08:55:32 pm
Lucas IP
« Reply #7 on: August 03, 2008, 08:55:32 pm »
if it's anything like the bosch, the pump cover needs to be taken off to get at the governor.
Reply #8August 04, 2008, 01:31:14 am
gigaz2
  • 626
Lucas IP
« Reply #8 on: August 04, 2008, 01:31:14 am »
Quote from: "nokivasara"
can you post a link to that info?
Reply #9August 04, 2008, 05:22:47 am
nokivasara
  • 115
Lucas IP
« Reply #9 on: August 04, 2008, 05:22:47 am »
I donīt remember what forum it was, itīs been months since I found it...Search the net for Peugeot and MG-diesel forums, I think that Ford Escort has a Lucas IP too, there ought to be some Ford Forums in the UK!
Found this, it has a pretty good explenation about the max fuel setting:
http://www.club-306.com/guides/306_turbo_tuning
It says that the max revs setting also raises the point where the rev limiter (governor?) kicks in, is that really true?
