Author Topic: NEED REAL FAST: Jetta MK2 crossmember  (Read 6973 times)
January 18, 2008, 12:42:21 pm
madmedix
  • 204
« on: January 18, 2008, 12:42:21 pm »
Hi Folks:
The crossmember let go on my 90 Jetta. Thought I had one locally after searching without luck only to find the doorknob pulled a part from a mk3 & tried to convince me it'll fit  :roll:
This is what I need (item 2 & might as well get #4 too):
This is why:
I'd really hate to part out this girl because I can't find this part... :cry:
Cheers,
Andy
'90 TD Jetta
Reply #1January 18, 2008, 10:43:30 pm
Baselyne
« Reply #1 on: January 18, 2008, 10:43:30 pm »
pm me!
im living in toronto and i may (if i can get it off the car) have one for you!
Reply #2January 20, 2008, 01:42:37 pm
madmedix
  • 204
« Reply #2 on: January 20, 2008, 01:42:37 pm »
pm sent!
'90 TD Jetta
Reply #3January 20, 2008, 08:13:37 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
« Reply #3 on: January 20, 2008, 08:13:37 pm »
I might also have one for sale in about 6mo or so too. I need to use it to jig up an aluminum setup though first ;) contact me if you really need to get it asap I have it out of the car..
Reply #4January 21, 2008, 03:31:26 pm
  • 5104
« Reply #4 on: January 21, 2008, 03:31:26 pm »
i thought the mk3 stuff does work?
Reply #5January 23, 2008, 01:34:04 pm
madmedix
  • 204
« Reply #5 on: January 23, 2008, 01:34:04 pm »
Trust me, I was praying it would, but not this part. Not even close. The engine mount is off by about 2" and on a different angle with respect to the motor. The strain on the rubber would have been nasty even if I used a crowbar to force it to mate up. The end-bolt holes also weren't the same.
'90 TD Jetta
Reply #6January 23, 2008, 02:25:09 pm
« Reply #6 on: January 23, 2008, 02:25:09 pm »
This guy should have one. He's a good guy to deal with
http://forums.vwvortex.com/zerouser?cmd=viewprofile&id=92971
Reply #7January 25, 2008, 05:53:19 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #7 on: January 25, 2008, 05:53:19 pm »
The part you are looking for is the lower radiator support. it is specific to the mk2. The other part is the crossmember. You might be able to convert the corrado or B3 Passat's lower radiator support. the Mk3 and b4 parts will not work at all.
You can NOT use a Mk3 crossmember
You can use a corrado crossmember as well as a B3 cross member.
I think I can get some relativly rust free Mk2 parts for about $40 at my local junk yard and then ship it to you But I would want the funds upfront. My wifey's ebay user name is www.joansbearbox.com if you want to see the feedback for confidence.
Reply #8January 26, 2008, 11:13:11 am
wyldman
  • Authorized Vendor
  • 403
« Reply #8 on: January 26, 2008, 11:13:11 am »
That looks like the crossmember is bad.The rad supports rust out all the time,but they are readily available and dirt cheap from the dealers ($75).
I just parted out an MKII and it is sitting behind my shop.It's yours for the taking before it goes to the scrap yard.I don't know exactly what shape it is in,but it is not broken.You can have it and the rad support,plus anything else you need off the car.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
Reply #9January 27, 2008, 10:39:32 pm
Baselyne
« Reply #9 on: January 27, 2008, 10:39:32 pm »
did you end up getting what you have been looking for?
I may have time monday to get that for you provided the weather isnt pure rain or freezing ice pelates
LMK man,,Pm me
Reply #10February 04, 2008, 03:38:07 pm
wyldman
  • Authorized Vendor
  • 403
« Reply #10 on: February 04, 2008, 03:38:07 pm »
I have pulled both the rad support and crossmember for him,he just needs to come get it.
(416)565-7282
Reply #11February 08, 2008, 09:00:53 pm
madmedix
  • 204
« Reply #11 on: February 08, 2008, 09:00:53 pm »
And go and get it I did. Wonderful shape!  :D
Folks, this gentleman also offered up any other bits I needed off the car before she heads out for her final drive...so I can get my girl past 500k (less than 50k to go...) and keep her alive...gratis. Right after the expense of moving...Much appreciated.
Thanks again,
Andy
'90 TD Jetta
