Author Topic: Garrett VNT 2056.  (Read 4568 times)
January 15, 2008, 07:19:25 pm
quietmission
  • 96
Garrett VNT 2056.
« on: January 15, 2008, 07:19:25 pm »
"Garrett VNT 2056 Euro part
Almost new Garrett VNT turbo GT2056. It came off of a Europe only Jeep.
Some specs are:
Compressor wheel: Inducer 40mm Exducer 56mm
Turbine Wheel: 43mm exducer, 45mm Inducer"
Will this work with an ALH?  How much work needed to make it work?  What is needed to do so and will it work good?  I need to know ASAP so i can make a decision to buy it.
"Let it keep on ticking"
Reply #1January 15, 2008, 08:48:08 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
Garrett VNT 2056.
« Reply #1 on: January 15, 2008, 08:48:08 pm »
olivers turbo would be a decent turbo for race use age. (I am assuming thats the turbo you are talking about ;)) I would say if you are looking for a daily the vnt hybrids are the best because of less lag. Now the 2056 is not a bad daily rig with good amounts of tuning upgrades....
At minimum you would need new oil lines for the turbo, and a 8v exhaust manifold to t3/t4 flange. (plus a custom downpipe for the car). Olivers price isnt bad if you have fabrication skills and abillity to do it yourself.
Other suggestions I would have for this would be...
1)pp764 nozzles or larger
2)upgraded cam
3)11mm pump
4)2.5" exhaust
5)chip tune ;) if you didnt already know that...
6)3 bar map
7)newer intake
8)head porting
9)lift pump
10)other suspension, braking, and tranny mods not needed to mention for performance sake.
Those items should get you a healthy 190WHP and a higher rpm band. BUT a 1752 1856 hybrid will net you more power under the curve and will be much better for street useage with the same mods...
hope this helps price is good
